Question about Rand Mcnally Intelliroute TND 510 Truck GPS
My 510 has a system file missing - Rand Mcnally Intelliroute TND 510 Truck GPS
Acer E1 510 won't let me get into windows8 it says something about files missing or if I have a media installion USB or disk
Hi Courtney
It sounds like you have some corruption on your system. This could be due to an improper shutdown (forced shutdown without closing files properly) or a defective hard disk (these can go wrong from day 1 so be aware that 'I only just got the laptop' does not mean that the hard drive is not defective).
First and foremost, have you got any data (documents, spreadsheets, music, pictures, emails on the laptop. The reason for my asking this is before I suggest any course of action, we need to get your data off your system. Now to get your data off (assuming you don't have the files in an intact backup file - either full or incremental) the try this link and follow the appropriate instructions
Recover files from corrupted hard drive with best data recovery software
Once you are happy that you have the data safe, I assume that your system is no longer in warranty (if so check with Acer to see if they can help) and that you do not have the recovery media created for your laptop. There may be an option to enter Recovery mode during the startup sequence, please look at the bottom of the screen while the laptop starts up. It will be before the laptop attempts to load windows. Hit the appropriate key, this is usually a function key such as f12, or f4 or similar. From here follow the laptop makers instructions to recover the system. A word of warning This Will COMPLETELY clear your harddrive and put a new copy of the operating system (windows 8/ 8.1) on the system. No DATA will be saved. Other than this the system needs to have recovery files, which may be available via Acer or alternatively look online for sites which make recovery files available at a cost.
This is a link to a copy of the manual, which you should have, but in case you don't
Acer Aspire E1 510 User Manual Windows 8 1
I hope this helps
Regards
Hayden Williams
Green Dragon Solutions
www.gds888.com
May 05, 2014 | Computers & Internet
I downgraded my hp 510 notebook from windows vista to XP then i installed the sound drivers but there is still no sound so what should i do?
try using driver scanner.. or extract the driver zip or browse it where it instaled in the device manager by right clicking the missing sound driver > Update Driver... then select for browsing ur pc for the driver files... then select the extracted or instaled folder..
Sep 02, 2010 | HP 510 Notebook
Is it possible to download and install jar files to lg 510 ? if yes, then how ? what is the procedure ?
download a jadmaker program,then make a jad & install and put it near the jar file.then brwose jad file in the pc suite & install it.
download jadmaker from here :
www.freewarefiles.com/JADMaker_program_18866.html
Aug 16, 2010 | LG Cell Phones
Dish 510 DVR that wont record properly or play paused TV show
Make sure that the software is correct. Should be P4.07
you can go into the DVR and replace the hard drive but I would suggest getting Dish Home Plan, Replace the receiver and then cancel the Home Plan. Talk to Dish Network and they will work with you.
for tech support go to: tech.dishnetwork.com
Dec 27, 2009 | DISH Network DVR 510 DTV Receiver /...
My system won't boot because the windows\system32\config\system
If i am from Singnet technical Helpdesk, we are advised to direct you to Acer Service centre if you owned an Acer computer with a serial number and if it is still under the warranty period on Operating system missing, Another option is to contact Microsoft service centre for CD replacement or oprating system advise since they are the suppliers and vendors for fathering the operating system, To troubleshoot your missing files,you need to know pecifically which files are missing and are they registered in your O/S and are they active and running or are they deactivated, takes longer time to solve missing files problems because you did not list what files are missing and you need to tell microsoft what files are missing in our operating system as there are thousand of files in the WIndows operating system
Jul 23, 2009 | Acer Aspire One AOA150-1983 Notebook PC
Will not print, showing error 6000
hello...
maybe some files of printer driver is missing i think deleted by the virus,,,or if you have virus scanner installed on you pc maybe last time when you activate the virus scanner have a file from your printer driver are infected,,, have a anti virus if not able to repair the infected files can do to delete automatically..
your best to do: remove the printer driver software uf your pc and install it again..purpose to make a new copy on your printer driver
how to remove? go to the control panel and click the (ad and remove program) and you can find the name of your printer driver high light it and click uninstall din restart you pc to take effect
or maybe your computer encounter a virus mas better to reformat using the operating system/os or put your printer into other computer and install your printer driver..
thank you!! hope i can help you.. have a good day!!!
Jul 06, 2009 | Cannon Office Equipment & Supplies
Tomtom go 510 battery won't charge and unit will not switch on
Claire.....honestly, it it going to ge a hit or miss if it is going to work or not.....just be prepaired if it does not work
Mar 06, 2009 | Tomtom GO 510 GPS Receiver
Windows dont start
It means that some files needed for windows to restart are missing,probably a system file or boot files. Some windows xp users usually re-install and repair their windows xp system using their original windows xp install disk and selecting the "repair" ooption. But another practical solution is to note down the missing file, then,on another PC using the same system,search for that file and copy, though you will have to note the folder location of that missing file from another PC. Boot your PC (the one that doesn't boot) with a system diskand on the command prompt (DOS prompt) copy the missing file from yourcopy disk to the same location where the missing file should be situated.
If the practical suggestion wouldn't work, then you have to re-install your windows on top of the current installation using your windows cd to repair yourwindows sytem, if this still doesn't then you have to install a new windows systemlocated in a different location in your disk, this way you still go to your saved files and backup your files.
Apr 18, 2008 | Microsoft Windows XP Professional for PC
TomTom 510 postcode
The postcode information has to be in a folder named ZIP. This can be either on the SD card or as a subfolder of the NAvigator folder in Program Files on your device
May 09, 2007 | Tomtom GO 510 GPS Receiver
Rand Mcnally Intelliroute TND 510 Truck GPS Logo
89 people viewed this question
Top Rand Mcnally GPS Experts
Michael Vincent Cruz
Steve F
Are you a Rand Mcnally GPS Expert? Answer questions, earn points and help others
