Question about Dodge Vehicle Parts & Accessories
My brother installed a 2000 jeep Cherokee motor in a 2001 jeep Cherokee . engine starts runs for 4 seconds but shuts off
Hook up to a code reader it might tell you what is wrong
Posted on Oct 18, 2013
QJUST HAD A USED EXVELLENT CONDITION ENGINE INSTALLED IN MY JEEP CHEROKEE 2000 NOW IT KEEPS ON STALLING OUT ANY IDEA WHY
It could be egr valve clogged,or ur catylic converter is clogged ,when it's hot it stalls,, cools down starts runs fine until hot again I believe it's your catylic converter, take it back to where u had motor installed. best of luck
Mar 08, 2015 | Jeep 2000 Cherokee Sport
2000 jeep Cherokee sometimes runs fine shut it off wont start but turns over fine later it will start
Ok. You didn't say what size engine was in the Jeep, but based on your problem, I'd bet its the 2.5L 4 cylinder. They had a classic issue with intermittent failure of the crankshaft sensor. This will cause the vehicle to just shut down without any other indications, Sometimes it will restart immediately, sometimes it can take minutes to hours to restart. The sensor is easy to replace and not very expensive. It is located on the drivers side of the transmission bell housing.
Nov 04, 2013 | 1998 Jeep Cherokee
2001 jeep gd. cherokee larado 4.0 4wd auto. when
Have you run an engine control system fault code test? If not do that first.
Jun 08, 2017 | 2001 Jeep Grand Cherokee
2001 Jeep Grand cherokee cooling fan runs on
Likely your fan relay internal contacts have burned closed. Relay should be either in the power distribution center or in front of the battery.
Nov 05, 2009 | 2001 Jeep Grand Cherokee
2001 jeep grand cherokee 4.0 engine shuts off
it is possable/likely a bad ECTS (engine coolant tep. sensor), this can cause the injectors to allow to much fuel into cylinders and cause a low compression and or flooding situation, good luck, marty
Jun 07, 2009 | 2000 Ford Focus
Auto start will start car then turn car off 3 or 4 sec later.
on most remote start application a wire is installed in motor with one wire on the fuel injectors that wire reads rpm if its to high it stalls if to low stall so check wire get back to me
Dec 27, 2008 | 1998 Jeep Cherokee
2000 jeep cherokee starts then stalls in approx 3 sec 4.0 has new crank sensor
I am going to assume that it will not run even if you push on the accelerator pedal?
Can you install or attach an old timing light to the spark plug wires, turn it one and try to start it. The light should flash with the engine running, but if it shuts off at time of engine die, and the engine is still spinning, you are losing spark, My suggestion is the cranks shaft sensor on bell housing.
Second, install a pressure gage on the test port on the fuel rail and watch it as you start the engine, fuel pressure should not drop as the engine dies, if it does, the pump is not working correctly. There are two modes of power to that pump, one to start and timed, for only a few seconds to prime the system, and one to run continuously. Find the wires going to the pump at the tank. Connect test light to those wires and watch what happens during crank and at stall, You should not have the pump shut off and the engine dies.
If you have spark, and fuel pump working, when did you last change the filter,,but I put that LAST.
It has to be one or the other of these.
Good Luck
Aug 04, 2008 | 2000 Jeep Cherokee
Vehicle Parts & Accessories Logo
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Ruben Diaz
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
