Question about Hansgrohe 06649860 Solaris Single Hole Kitchen Faucet with Base Plate - Ste...
My house is only 2 years old and has begun making a "hammering" noise when I turn on the cold water tap in the bathroom only. The water will actually stop flowing in a moment or two.
  • 39 Answers
If the water actually stops running it might be a problem in the internal balancing valves. Some valves will restrict flows of the other water-supply: If there is slow hot water it throttles the cold water, if there is slow cold water it throttles the hot water. It is meant to stop the screaming in the shower if a toilet for example is flushed and the cold water pressure drops. Some but not all valves can be taken apart and cleaned. Turn off both shut off vavles first!
Posted on Oct 18, 2013
Noisy water pipes when neighbours use water
Install air chamber to cushion sudden-stop of flowing water.
Water flow coming to sudden stop is called water hammer, and will bang pipes, but also loosen plumbing joints, causing leaks.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#bang
http://waterheatertimer.org/images/Flow-rates-water-hammer-600.jpg
Air chamber has to be vertical, and about 18" long, with cap on top.
By code each Hot and Cold line at each tap will have air chamber located behind the wall. So there are two air chambers at each tap.
In your case, you can probably add air chamber to your Hot and Cold lines and solve problem for both dwellings.
Water hammer is caused because water does not compress like air.
So when long column of water suddenly stops... the whole pipe-full of water comes to sudden halt... and that water could weigh 1-1/2 pounds ... and just like a hammer head moving, the weight of water bangs the pipes to dissipate energy, causing noise.
Apr 21, 2013 | Water Heaters
Air in bathroom cold water pipes
You have to install anti knock pipes into your plumbing, it's quite common. Go to the local home center you can by pre made or make your own as I did when remodeling my basins. Good Luck..
Oct 20, 2012 | Home
I have a new uberhaus shower faucet lever type with seperate diverter.prior to install i had no noise problems now i do i have checked all pipes to make sure that they are well atached to framing.i have...
indicates that you have ceramic 1/4 or 1/2 turn inserts in the taps
These taps are very quick action taps and the water flowing is stopped immediately resulting in water hammer
The air chambers you have installed ( accumulators ) may be working but the pipes will suffer the water hammer all the way back to the utility tap on the foot path
Find out the utility pressure to the house and then you may have to install a pressure regulator on the inlet pipe to reduce that pressure to stop the water hammer
Feb 12, 2018 | Home
Water hammering after disconnecting a washing machine. I have just replaced our old washing machine that took a hot and a cold feed, with a new washing machine that only takes a cold feed. I have turned...
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
Jun 02, 2011 | Plumbing
I have 2 bathrooms with a common wall. We hear a constant low tap of the pipes in the wall between the bathrooms. We have checked toilets, sinks, faucets, etc for leaks. Sounds as if there is pressure or...
You have water hammer effect it is caused by a fast closing valve,it can be solved by installing a water hammer arestor in the plumbing line or maybe the water pressure is too high and a pressure reducing valve can be installed in the main water line.(the pipes in the wall are not secured properly that's why they vibrate)
May 19, 2011 | Plumbing
What causes pipes to bang when hot water tap opened may be air locks but water seems to flow okay but the noise causes concern
no water hammers installed above the water heater. You can buy these hammers but they are not fun to put on yourself
Apr 08, 2011 | Home
5 year old Frigidaire top freezer works ok but makes a\poppng sound on shutdown.
Would you describe it as a popping or more like a knock sound? You may have a bad spring inside your compressor allowing the piston housing to contact the case wall of the compressor. It usually sounds like someone tapping a thick piece of steel with a hammer.
If the pop noise occurs well after the unit shuts down it may just be the liner has contracted from the cold and is shifting around, make sure it is not set too cold.
Jun 11, 2010 | Frigidaire Refrigerators
No cold water from bathroom tap
Sounds like you need to replace your shower valve, especially if this is the only fixture in the house being affected. You could try to replace the cold water cartridge first. Hope this helps
Jul 06, 2009 | American Terminal Etc B 100 T Taps
Clunking noise in sink
You are describing a problem known as water hammer. This will ultimately cause damage somewhere in your plumbing system so it should be addressed. If you are handy you can install an air chamber near the sink. If you want more information let me know. good luck.
Jan 17, 2009 | Home
Hansgrohe 06649860 Solaris Single Hole Kitchen Faucet with Base Plate - Ste... Logo
148 people viewed this question
Top Hansgrohe Plumbing Experts
GCcontractor
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
