Question about Acer Computers & Internet
How can i Resolve efficiently this specific intermittent connection problem. -I'm using Wi-fi at home. -I'm using a Tp-Link TL-Wn722N High-Gain Wireless Key. -The problem occurs under windows XP Home Edition. -The Problem doesn't occur on Linux or any other computer using Win7 or later and Wi-Fi. --The signal is Full Strength or sometimes 4bars. -The problem occurs when I boot. -The VPN is Offline. IpConfig shows the same adress for IP and DNS ????? -I reset The Nic it doesnt change anything -I try to repair via the windows textual Option ( sometimes It works, sometimes it says cannot establish a connection to DNS) -I try To Flush DNS + IP Renew (most of the time it does'nt work, but sometimes it does.... -_-) Any Suggestions ?
    Problem Solver:
  • 18 Answers
Not sure what your actual question is. Are you saying that your WinXp machine cannot connect to the wireless network at boot time, but then it is able to at some later time? Please start with the explicit issue you have, and we can go from there.
Posted on Oct 18, 2013
Testimonial: "exactly, could it be link to 127.0.0.1 ?"
  • 10 more comments
  • alex trep
    alex trep Oct 18, 2013
    Because I'm getting an error of loopback when i try to launch Postgresql database.
  • alex trep
    Connected or not... I don't know maybe I'm saying whatever that land in my head....
  • alex trep
    This might have no influence at all...
  • Greg Baumbach
    Greg Baumbach Oct 18, 2013
    Again, you need to explicitly state your problem in order for someone to render a diagnosis. What is it you cannot do--surt the web, use a particular application, etc.?
  • Greg Baumbach
    Sorry, just started using FixYa, didn't see your first comment. Ok, so your internet is working, but you are getting errors connecting to your Postgresql database. Got it. Is your database hosted out on the web somewhere? What tool are you trying to connect to it with?
  • Greg Baumbach
    FYI, a loopback is where you're running Postgresql on your local machine. Is that the case?
  • alex trep
    Yes it's the case , The database is hosted on my machine at my home, on windows xp, the tool im trying to connect with it is Holdem Manager.
  • Greg Baumbach
    OK. The it's definitely not your network. You run this on several machines, each with their own copy of Postgresql (and HoldEm Mgr), and only this box fails to work, correct?
  • Greg Baumbach
  • Greg Baumbach
    If you can post the exact wording of the error message too, that'd come in handy.
  • Greg Baumbach
    Also, have a look here: http://faq.holdemmanager.com/categories/...
  • alex trep
    thank you
Daxtor2007
  • 85 Answers
SOURCE: Repairing Damaged Winsock2
1. Boot the computer using the XP CD. You may need to change the   boot order in the system BIOS. Check your system documentation
  for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the
  options below This portion of the Setup program prepares Microsoft
  Windows XP to run on your computer:
  To setup Windows XP now, press ENTER.
  To repair a Windows XP installation using Recovery Console, press R.
  To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup.
  do not choose "To repair a Windows XP installation using the
  Recovery Console, press R", (you do not want to load Recovery
  Console). I repeat, do not choose "To repair a Windows XP
  installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing
  Windows installations.
  5. Select the XP installation you want to repair from the list and
  press R to start the repair. If Repair is not one of the options,
  read this Warning!!
  6. Setup will copy the necessary files to the hard drive and reboot.
  Do not press any key to boot from CD when the message appears.
  Setup will continue as if it were doing a clean install, but your
  applications and settings will remain intact.
  Blaster worm warning: Do not immediately activate over the internet
  when asked, enable the XP firewall
  [ http://support.microsoft.com/?kbid=283673 ]
  before connecting to the internet. You can activate after the
  firewall is enabled. Control Panel - Network Connections. Right click
  the connection you use, Properties, and there is a check box on the
  Advanced [ http://michaelstevenstech.com/xpfirewall1.jpg ] page.
  7. Reapply updates or service packs applied since initial Windows XP
  installation. Please note that a Repair Install from the Original
  install XP CD will remove SP1/SP2 and service packs will need to be
  reapplied.
  Service Pack 2
  http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-
  4F30-8245-9E368D3CDB5A&displaylang=en
  An option I highly recommend is creating a Slipstreamed XP CD with SP2.
  Slipstreaming Windows XP with Service Pack 2 (SP2)
  http://www.winsupersite.com/showcase/windowsxp_sp2_slipstream.asp
  ______________________________________________________________________
  Warning!!
  If the option to Repair Install is not available and you continue
  with the install;you will delete your Windows folder and Documents
  and Settings folder. All applications that place keys in the registry
  will need to be re-installed. You should exit setup if the repair
  option is not available and consider other options.
  Try the link below if the repair option is not available.
  Windows XP Crashed?
  http://www.digitalwebcast.com/2002/03_mar/tutorials/cw_boot_toot.htm
  Here's Help.
  A salvage mission into the depths of Windows XP, explained by a
  non-geek
  by Charlie White
  Related links
  You May Lose Data or Program Settings After Reinstalling, Repairing,
  or Upgrading Windows XP (Q312369)
  http://support.microsoft.com/default.aspx?scid=kb;en-us;Q312369
  System Restore "Restore Points" Are Missing or Deleted (Q301224)
  http://support.microsoft.com/default.aspx?scid=kb;en-us;Q301224
  How to Perform an In-Place Upgrade (Reinstallation) of Windows XP
  (Q315341)
  http://support.microsoft.com/search/preview.aspx?scid=kb;en-us;Q315341
  Warning!! If the Repair Option is not Available
  What should I do? Most important do not ignore the information below!
  If the option to Repair Install is NOT available and you continue
  with the install; you will delete your Windows folder, Documents and
  Settings folders. All Applications that place keys in the registry
  You should exit setup if the repair option is not available and
  consider other options. I have found if the Repair option is not
  available, XP is usually not repairable and will require a Clean
  install.http://michaelstevenstech.com/cleanxpinstall.html
  If you still have the ability to access the Windows XP installation,
  backup all important files not restorable from other sources before
  attempting any recovery console trouble shooting attempts.
  Possible Fix by reconfiguring boot.ini using Recovery Console.
  1.Boot with XP CD or 6 floppy boot disk set.
  2. Press R to load the Recovery Console.
  3. Type bootcfg.
  4. This should fix any boot.ini errors causing setup not to see the
  XP OS install.
  5. Try the repair install.
  One more suggestion from MVP Alex Nichol
  "Reboot, this time taking the immediate R option, and if the CD
  letter is say K: give these commands
  COPY K:\i386\ntldr C:\
  COPY K:\i386\ntdetect.com C:\
  (two other files needed - just in case)
  1. Type: ATTRIB -H -R -S C:\boot.ini DEL C:\boot.ini
  2. Type: BootCfg /Rebuild
  which will get rid of any damaged boot.ini, search the disk for
  systems and make a new one. This might even result in a damaged
  windows reappearing; but gives another chance of getting at the
  repair"
Posted on Oct 20, 2008
SOURCE: trying to connect to my
limited or no connectivity means your wlan not communicating with the router, check if you turn on the wlan switch on your laptop or try to install updated driver for you wlan
if thats a external wireless lan card try to unplug and plug it back.
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: Lost IP adress
You Would Need to speak to your Internet Provider (IP) and they will have a step to step guide on how to reconnect your internet
Posted on Jan 20, 2010
wildbear6
  • 192 Answers
SOURCE: I recently rebooted my computer and the windows
have you tried to fully reset your router? you can turn off your modem and router, but some routers have built-in batteries so have a reset button on the back usually, more often then not you need a pin or something small to get to your router reset button, keep it pressed in for atleaset 5seconds, then leave your router to reset on its own for a few moments, then turn on your pc and try the internet again. I say this as you may just have an IP conflict.
Posted on Jan 26, 2010
  • 11800 Answers
SOURCE: my internet access through my ethernet cable keeps
Either that or the ethernet chip on the motherboard is failing - you will need to disable this one from the BIOS and install a simple PCI LAN card in its place
Posted on Aug 26, 2011
Testimonial: "thank you - i will give that a try"
Network operater for WiFi router lumia 510
https://www.youtube.com/watch?v=ptjVQXmfLKA
Wi Fi needs a router with Wi Fi that is transmitting its identity with an ssid http://www.webopedia.com/TERM/S/SSID.html
Where are you trying to connect lumia 510 to. Is it at home do you have an existing internet router with several ethernet ports on the back of it. If yes then you need a Wi Fi access point or Router.
https://en.wikipedia.org/wiki/Wireless_access_point
http://www.4cabling.com.au/tp-link-wireless-54m-access-point-tl-wa501g-14622.html#.VayN1fk_yrY
Jul 20, 2015 | Computers & Internet
MY PROBLEM HOW TO CONNECT WIFI
setting up a Wi-Fi connection is the same process as setting up a wireless Internet network.To get help,see:Setting Up a Netgear Wi-Fi Router
Aug 26, 2012 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
TP-LINK TL-WN722N Wireless USB Adapter not connecting internet radio
use another suitable driver like
http://www.techspot.com/drivers/driver/file/information/17000/
if not the driver work with adapter ,there may mot work. I was installed downloaded driver first time worked ,but after few days it was not worked ,i tried to install another driver. problem solved.
Jun 05, 2017 | TP-LINK TL-WN722N Wireless USB Adapter...
I have Windows 7 64-bit Home Premium on a Gateway desktop computer. I plugged in the newly purchased TL-WN722N wireless adapter and installed the driver from the CD. I connected to the Linksys WRT54G...
Dear ubose1, This is Howard from TP-LINK Support Force. Maybe the anti-virus software blocks the driver installation. Please disable the self-defense function and exit it. Then try to install the driver again.
TP-LINK Support Force http://www.tp-link.com/en/support/ http://www.facebook.com/TPLINK
Sep 18, 2011 | TP-LINK TL-WN722N Wireless USB Adapter...
I can not get signal wi-fi when i try TP-LINK TL-WN722N connected to PC...but when i try in notebook there is no problem.My notebook and PC have same OS,thanks
Usually ordinary desktops doesn't have the capability to connect to a WLAN Network because there won't be any WiFi antenna embedded on the motherboard.But in the case of laptops for the ease of use of network services wherever you go they come fitted with WiFi antenna and hence can connect to a wireless LAN network by the flip of a switch.Connecting to a Wireless LAN network has nothing to do with OS because it is a Hardware feature.Please don't forget to rate me if satisfied with my solution.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 18, 2011 | ASI TPL WL TLWN722N 150Mbps USB Wireless...
Computers & Internet Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
