Question about Briggs & Stratton Garden
Starter motor has not enough power to turn motor over when cold
    Sergeant:
  • 216 Answers
A couple of issues could be causing this issue.
First thing is to check the engine oil and see that it full and not to thick or the incorrect grade of oil.
Secondly, I would make sure that the battery has a full charge and that you check all the connection.
This issue is most often caused from batteries not being removed in the winter and the battery goes dead and in the the summer months it's charged often enough to start. However batteries loss some of their ability in cold weather to crank as hard. so therefore a battery that has froze or been disharged in the winter is usually the culprit.
Posted on Oct 20, 2013
Try to start my suzuki grand vitara v6 and the motor won't fully turn over. But the starter is doing its job, and there's full power inside vehicle.
Even if you have power the starter is not getting enough cold cranking amps to fully turn the starter.
Charge or jump battery.
This can also be caused by dirty batt cable connections clean them at batt if not fixed clean and tighten at starter
Hope this helps mike
Jan 30, 2016 | Suzuki Cars & Trucks
How to diagnois problem with no scanner
Eliminate the battery as the issue first up.
Check if you can jump start the car from another vehicle with its engine running or at least have the starter motor kick over the engine. If it starts then you know your battery is the issue. Having lights does not mean the battery has enough cold cranking amps to turn over the starter motor.
2. If the starter cranks the engine over as normal with a jump start from another car but your engine does not start you have also eliminated the starter motor as the issue.
3. If it does not start and the starter motor will not crank the engine over either when you jump start from another vehicle, then there may well be a problem with the starter solenoid, the starter motor itself or with the wiring to the starter solenoid or to the starter motor. No power getting to the starter motor solenoid or to the starter motor and obviously the starter motor will not turn over.
4. So I need not write much more here, there is a very good guide to solving starting issues here which I suggest you might like to read.
No Start Problems
Jan 14, 2016 | 1996 Dodge Caravan
1998 850 timberjack feller buncher 6cyl cummins Lots of power to gauges and heater radio but will not start
Diesel I presume. Does it "turn over" but not start? What does exhaust look like when if it does turn over? If white smoke, you have bad compression. Otherwise, all critical systems are Fuel filter. Glow plug system and their timer. Sometimes cycling of the glow plug system in very cold weather may help. If the solenoid engages, but starter will not turn the motor, you may have enough power based on other devices. But it does not necessarily mean there is enough capacity to supply the starter to turn the engine. If the engine turns, Starting fluid may help. But if it does not continue to run, there is definately a fuel supply system problem.
May 05, 2015 | Cars & Trucks
Tdi clicks on cold start
Sounds like a flat or faulty battery. Try getting a jump-start from another vehicle. The clicking is probably from the starter relay.
The relay operates with a click switching the power through to the starter motor. If the battery is low, the starter motor draws so much current that it effectively short circuits the starter relay which releases.
Now the starter motor is disconnected, there is enough current to re-operate the relay, another click, and the starter motor is reconnected and short circuits the relay again etc. This clicking continues until the battery runs completely flat or you stop turning your key.
Jan 24, 2014 | Volkswagen Cars & Trucks
My husqvarna zero turn rz4621 starter is getting enough voltage, but isn't putting out enough to start my briggs and straton motor. have checked with meter starter and silinoid, have had battery checked...
it maybe that the battery is getting old or is not the right rating if the AH Start rate is too low it will not have enough power to turn the starter motor. ensure the battery you use has enough Starting Amps rated. if this is not the issue have the starter motor checked out.
I hope this was useful.
Oct 31, 2013 | Husqvarna Mower Rz4621 Zero Turn
Car doesn't want to start when warm
indicates a faulty starter motor
remove it and have it bench tested first as it is possible to have it repaired
Jul 16, 2017 | Cars & Trucks
In cold weather car cranks, but it does not have enough power or fuel to get it started. Have new battery. Have had to use starter fluid as well as a jump to get it started in this cold weather. What could...
a worn out starter could do it if the bushing in it are worn it would pull to much power from the battery and would not turn the moter over fast enough to pump enough gas to start the car if its carberated then it has a manual fuel pump the fuel pump wont pump enough gas if the moter is not turning over fast enough i would either rebuild the starter or replace it.
Dec 04, 2010 | 1989 Buick Skyhawk
1994 triumph trophy,starter motor clanking in and out does not turn engine enough to fire from cold, starter motor or starter motor clutch? how do i get it out to check it?
I yes install a new Battery evry 2 years , The battery since to loose the apm, Juse, and can damage u starter, is cheaper to replace the battery,,
Oct 07, 2010 | 2002 Triumph Trophy 1200
Starter motors good but wont turn over my1982 lincoln continental
When you say the starter motor runs, do you mean it runs fast but does not turn the engine, in that case it may be something to do with starter not engaging the ring gear.
If when the starter runs it turns the engine slowly then it could be starter is not getting enough power.
The reasons for starter motor not getting enough power can be, a bad battery, loose battery connector, stiff engine or a bad starter solenoid.
To check a bad battery, turn your head lights on and when you try to crank the engine, if the light go dim, you have a bad battery or a bad battery connection. If the lights are not affected you may have a stiff engine.
Mar 02, 2010 | 1994 Chevrolet Camaro
My 07 Odyssey is not starting in today's cold. There's a clicking sound when I turn the key. Battery is fine. Owners manual indicates it may be a blown fuse, but diagram isn't very helpful in narrowing...
If you are getting a clicking sound, then the starter is not getting enough power. There are three major things that must work in order for a starter to work. A good power source with good connections, a good starter solenoid (puts direct battery power to the starter motor when you turn the ignition to start), and a good starter motor. Usually a clicking sound indicates a fault in the first two items mentioned. If it were a blown fuse, you would get absolutely nothing when you turned the ignition key.
Jan 10, 2010 | 2007 Honda Odyssey
Garden Logo
56 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
