Question about RCA RS1285 CD Shelf System
I cant find aux bottom on my rca rs1285 cd 5 changer. i want to play music to my mp3 from my stereo using my 3.5mm audio cable
  • 341 Answers
There is no AUX input on your system. That is a headphone output jack, not an input. There appears to be an AUX button on the repmote, but the manual indicated that it does not work. See the link below. Sorry for the bad news.
http://www.manualslib.com/manual/313546/Rca-Rs1285.html?page=6#manual
Posted on Oct 19, 2013
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Aux wire?
Your query > ..."wire...to hook...mp3 player ...RCA RS2044 stereo..."
You need to connect the headset out of your MP3 player using a special cable to theInterfaces/Ports: AUX-in of the RCA RS2044.
One of the many technical name for the special cable is RCA Male Stereo to male baby phone stereo, the common name is MP3 to RCA and it is similar to the function and look of a Cygnett Groove Transit - MP3 Phone to R...
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 29, 2007
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
  • 15 Answers
SOURCE: Buzzing sound and can't open stereo
Again RCA stereos **** for this factor, cheap transformers, replace the transformer and see if that helps as it seems to be the most problem with most RCA systems I've repaired in the past.
Posted on Jun 24, 2008
Does using an ipod/AUX adapter through the CD changer input stop a real CD from working?
you have to change it from the Aux setting to CD when you want to play cd, some cd players switch to aux. automatically when you plug inthe aux. cable. and may have to be unplugged when playing cd.
Nov 28, 2014 | Car Audio & Video
Rca 5 disc changer rs2130i
Buy a lead with headphone jack to red and white RCA/phono. Jack goes to iPad/iPhone/MP3 player. Red and white goes to Aux/Game/Line input socket if the unit has one. Play your music.
Sep 01, 2014 | RCA RS2130i Shelf System
Need help connecting to PC
You need adapter cable 3.5mm mini stereo plug to double RCA plugs (one red, one white). Plug 3.5mm end into headphones/audio out socket on PC, RCA plugs to AUX IN sockets on rear of SA-222, select AUX on front of SA-222 to hear audio from PC through system speakers.
May 03, 2017 | Panasonic Technics Sa-222 Receiver
RCA Shelf System 1285 manual
Retrevo has the manual here: http://www.retrevo.com/support/RCA-RS1285-manual/id/402ci676/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
Jun 14, 2011 | RCA RS1285 CD Shelf System
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 13, 2011 | Pioneer VSX-D409
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
How do you hook up your ipod through the rca cable hookups in the back without the radio still playing?
This is different on every stereo, but generally the RCA ports in the back of the stereo are labeled "Aux" or something to that extent.
First, you must purchase a headphone jack to RCA cable which can connect to both your stereo and your ipod.
Connect the cable, turn your ipod on and start playing a song. Turn the volume on the stereo to a moderate volume so you can hear when the song is being played through your stereo. Then, using the selector switch, turn the stereo from "Radio" to "Aux" or whatever it says next to the the RCA plug ins on the back.
Aug 14, 2009 | Pioneer DEH-2000 CD Changer
Fiat punto mp3 or not?
I cant say about the mp3 disk but the aux is auxilary and the leads are located behind the stereo system yellow and red, you can buy the removal pins from most motor factors.
Apr 17, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
Jan 24, 2009 | Car Audio & Video
RCA RS1285 CD Shelf System Logo
287 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
