Question about Sewing Machines
I cant get upper thread to pick up bobbin thread
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Are you holding the end of the top thread whilst trying to pickup the bobbin thread? Put a BRAND NEW needle in - it may look OK, buy the slightest bend will be an issue. Is it the CORRECT needle for you machine? - check your manual. Is the bobbin in the case correctly and feeding out the correct direction? ...... timing may be out Good luck!
Posted on Oct 19, 2013
SOURCE: needle not picking up bobbin thread
Check the timing.
Posted on Mar 06, 2008
SOURCE: Bernina 801 Sport
Did you clean out the lint under the plate?
Posted on May 18, 2008
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Posted on Aug 29, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
Sewtech1
  • 69 Answers
SOURCE: The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
Posted on Jan 22, 2010
I sewed a support seam on neck line. got the bumpy stitches from bobbin. rewound bobbin, threaded machine. went to sew and now nothing works. it wont sew.
Not quite sure since the symptoms are not clear. "Bumpy stitches from bobbin"--does that mean there were thread nests on the bobbin side of the fabric? That is thread nesting or bird nesting resulting usually from mis-threading, upper thread not completely seated in tension disk, or upper tension too loose. Remove the upper thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning--verify the thread path is correct. Set the upper tension to the midway point between high & low number and retest the machine. (Upper tension may need to be tweaked because fabric, thread, and age of the machine will have an affect.)
Check that the bobbin is wound smoothly--no lumps, bumps, or thread ends/pieces sticking out of the bobbin. Check that the bobbin is installed in the bobbin case correctly (turning the proper direction) and the bobbin tension is threaded completely.
If the upper thread is not picking up the bobbin thread, make sure to install a brand new needle. (I don't try to straighten or "fix" damaged needles. With today's computerized machines, it may cause more damage than a new needle would cost. That may work on the old mechanical machines like the Singer Featherweights, but my machines are too important to risk for the price of a needle.) If it still won't pick up the bobbin thread, then the machine's timing has probably been knocked out of alignment. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
Problem with singer 590c. Thread bunches up & breaks or the bobbin thread wont sew. 1 time happened to get everything right & it sewed beautifully.Today I cant get it to pick up the bobbin thread.
Make sure to use a brand new needle.
ALWAYS RAISE the presser foot when threading.
Unthread and re-thread from the beginning.
Verify the thread path is correct.
Set the upper tension to midway between High & Low numbers.
Verify the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly and check the result. The upper tension can be tweaked so the upper & bobbin threads meet in the middle of the fabric.
If it is still not working properly, the machine may be out of time and require service.
Nov 20, 2016 | Singer Sewing Machines
My Ruby Viking will not pick up bobbin thread
Install a brand new needle. A bent/damaged needle sometimes will not pick up the bobbin thread.
Verify the machine is threaded correctly.
If it still will not pick up the bobbin thread, most likely it is a needle/hook timing issues. There are many web sites and videos online explaining sewing machine timing. Or take it for service.
Aug 19, 2016 | Sewing Machines
When thread cotton. Cotton don't pick up bobbin cotton please help bernette65
Be sure to use a brand new needle. A bent/damaged needle may have difficulty picking up the bobbin thread.
Verify that both upper and bobbin threads are threaded correctly. If so, and it still fails to pick up the bobbin thread, most likely there is needle/hook timing issue. Take it for service.
I am having problems with the bobbin its not picking up the bobbin thread through the needle
thread the upper part and the needle put presser foot down hold loose end of thread with felt hand and turn the wheel with right . the needle goes down shuttle wraps the bobbin thread around the upper and when needle comes up the bobbin thread will be with it . OR have yo MOMMA SHOW U HOW
Feb 18, 2015 | Sewing Machines
I cannotl get my 270 D to even sew, it will not pick up the bobbin thread and do a thing. I have yet to sew the machine. donna
Picking up the bobbin thread has to be done by manually. Turn off the machine, open the bobbin door, lift the presser foot, hold the end of the upper thread and slowly turn the side wheel till the needle enters the bobbin race and on the way up it will catch the bobbin thread. Pull the upper thread till you lift the bobbin thread too. Put both threads to the back of the machine, close the bobbin door and you should be able to sew.
Apr 03, 2011 | Brother SE-270D Computerized Sewing...
My bobbin thread will not thread. When I bring the needle down, it comes up without the bobbin thread. The mechanism moves, but no thread. How do I fix this problem?
check the bobbin to make sure it's not warped
check the needle to make sure it's not bent-roll on flat surface to see if it roll correctly
make sure the bobbin is in the bobbin case correctly
make sure you have a 3 to 4 inch tail on the bobbin-so the upper thread can pick it up easily
make sure you have a 3 to 4 inch tail on upper thread also as it picks up the lower thread
or you can hold the upper thread with your hand to the side of the machine & use the handwheel to lower the needle as it picks up the lower thread
pull both threads to the back behind the needle
make sure there is no lint or loose threads in the bobbin area
Sep 01, 2010 | White Sewing 2200 Multi-Tasker
Upper thread not being picked up by bobin thread
Is the under thread getting all bunched up?
Mar 23, 2009 | Sewing Machines
Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
Sewing Machines Logo
69 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
