Outside unit running ,inside stopped - Heating & Cooling
  • 2,113 Answers
Try turning off the double breaker for that unit and turn it on again and see if it resets
Posted on Oct 18, 2013
4 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Posted on Oct 28, 2007
  • 142 Answers
SOURCE: Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Posted on Jun 05, 2009
  • 10865 Answers
SOURCE: Inside fan running outside not
There is an electrical box on the wall near the outdoor unit. open it and be sure that the circuit breaker is in the on position. Same in your electrical panel, be sure that the circuit breaker is turned on.
Posted on Aug 16, 2009
Unit stopped cooling, inside unit runs, outside unit does not
could be a gas leak ( low gas pressure shut off switch, failed start run capacitor for the compressor , vermin problem shorting out the power board outside
The inside unit is just a fan
call an accredited ac technician to get a proper diagnosis and quote
Aug 06, 2016 | Heating & Cooling
Why is my Intertherm P681S unit getting hot and the fan is is stopping?
Is the outside running? Is the outside fan running? Probably what is happening the fan outside quits running and the compressor gets hot and goes into thermal overload. need to check to make sure the outside fan is running.
Aug 30, 2014 | Heating & Cooling
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
Coleman A/C-Heat Pump Start and Stop Run Problems
well you have it great job! on the out door unit when it will not shut off disconnect the yellow wire on the stat wires coming from inside if unit stops stat bad if not contactor "points' if they look pitted or buzz change them #1 reason for compressor failure high amp draw thru bad contactor hope this helps aboout 15.00 at hvac store seperate wires with zip ties so dont get mixed up if only one set of points then 30amp single pole 24vac coil contactor
Jun 04, 2009 | Coleman Mach III Air Conditioner
Jun 03, 2009 | Heating & Cooling
Air conditioner not geting cool
Hello, It sounds to me like your low on freon/refrigerant. You'll need to have someone test the pressures for you.
Jan 24, 2009 | Fujitsu 24C1 Air Conditioner
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
