Question about HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 scaner error3 - HP LaserJet 3055 All-In-One Printer
  • HP Master
  • 1,121 Answers
Reason:
CCD unable to detect the home.
Solution:
# Clean CCD unit(internal mirrors & lamp reflector). # clean flat bed glass. Fix back & chk. If not resolved chk CCD ribbon cable, # replace CCD unit..
CCD unit:
Posted on Oct 18, 2013
  • silver fox
    silver fox Mar 16, 2014
    you need a formatter! OR try cooking the board, the solders HP uses these days are cold.
    New Friend:
  • 23 Answers
NO! Now in proper grammar. The black sensor needs to swing freely. Its the black plastic swing thing that blocks the U shaped sensor.
Posted on Mar 16, 2014
SOURCE: HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Posted on Feb 19, 2008
SOURCE: Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I am unable to scan in pdf format under vista window
Posted on Mar 23, 2009
xptareq2000
  • 1447 Answers
SOURCE: HOW TO CLEAR PAPER JAM HP LASERJET 3055?
please you see your copier paper feed sensor is open or delivery sensor is open or broken
Posted on Jun 28, 2009
  • 102 Answers
SOURCE: HP LaserJet 3055 scan over network.
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
WIA scanner driver for HP laserjet 3055
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=1140612
Jun 05, 2016 | HP LaserJet 3055 All-In-One Printer
I have HP laserjet 3055 when i use a scaner i see: There is no paper in the document feeder. What this?
Remove adf input tray,lift adf unit cover observe black sensor flag fixed in side of cover this flag play in to the sensor locate the sensor clean with small brush,care fully observe the sensor location, fix back, check.
Sep 21, 2011 | HP LaserJet 3055 All-In-One Printer
How to remove the hp laserjet 3055 scaner pcl 6
If you are using Windows you can go to the Control Panel. Click on the add/remove programs icon and then let it populate. Once the list appears find the Lexmark software/driver and click it. When it asks if you want to uninstall click yes. Allow it to finish. Then before rebooting disconnect the printer cable so that Windows will not attempt to reinstall. Reboot and it should be gone. Hope this helps.
Aug 24, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 02, 2008 | HP LaserJet 3055 All-In-One Printer
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Scaner is not working of hp3055 color laserjet printer
Step 1:. Check Hardware Driver Installed Properly
- My Computer-Properties-Hardware-Device Manager
- If Yellow mark in printer and Scanner field, the Printer
driver not installed properly.
- So reinstall Printer Software
Step 2: If Scanner Option only not working,
- Go to Scanner Settings(Start-Programs.....)
- Choose Correct Scanner Name.
Or
- Press the Scanner button in hp 3055
- If Hardware driver was installed correctly, its automatically
deduct on your PC
Jul 02, 2008 | HP Color LaserJet 2600n Printer
Printer light contious blinking
first you can chek your scaner assemble.
then chek proper conect cable
May 27, 2008 | HP LaserJet 3055 All-In-One Printer
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
Nov 02, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
115 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
