Question about Pool & Spa
We put our intex pool up and when it was full, the left side rail was not straight, how to fix it.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
What if you shim under the verticals
Posted on Apr 19, 2014
  • 368 Answers
SOURCE: i have a 15 ft by 48 inch intex pool and i just
The most obvious thing besides not having salt in the pool has no stabilizer in it. This is a chemical that has an affinity for chlorine ions and if it is not there the chlorine can be disipated in a few hours when the sun hits it. Another name for it is Cyanuric Acid. It can be purchased in granular form at many pool supply stores or in a liquid form at Leslies. In order to get your pool blue you need to have the chemistry checked at a pool store or with a test kit (either liquid or strips). Don't buy everything a pool supply tells you to buy but start out with vinyl safe shock, stabilizer and salt. The pool store should be able to help you determine the dose. The following is what I would do:
1. Make sure salt is at the recommended concentration.
2. Shock the pool to recommended dose to start killing the algae.
3. Place the recomended dose of stabilizer in the pool.
4. Make sure pump and filter are working properly.
5. Check the pool chemistry on a daily basis until it is ready for swimming.
6. Check the chemistry on a weekly basis and clean the pool and equipment according to the pool instructions.
Smile, you are a pool manager.
Posted on Aug 22, 2009
  • 22 Answers
SOURCE: crooked ''legs'' intex pool
Should be ok, it really depends on the angle, mine are prolly a few inchs off on some, but im not worried with mine. im pretty sure you will be ok.
Posted on Jun 17, 2010
  • 31 Answers
SOURCE: i just put up a
Well there are two solutions.
1st: fill the pool with water. (yes it will be leaking)
Get a small bowl and put some dish soap in it.
Next tape a sponge or a rag (or something you can apply the soap with) and scrub down the sides with the soap. Because the soap reacts with water and releases oxygen (or Co2, I'm not sure) when it does, it will bubble up and reveal where the leak is.
I think that's the most reliable way. Another way is only reliable if the leak is large. You can make everyone get out of the pool and listen very carefully at each side. If the leak is large enough you'll hear a sizzling.
I think that the first method would be more efficient, but the second sounds like it might do the job as well and would be easier.
To fix the hole, I believe that you'll have to fix it with a patch kit. The link below lists a few different options. It's essential to have a patch kit when you have a vinyl above ground pool because it's incredibly easy to get a hole in the side. I'd suggest buying a quality patch kit to insure that the patch lasts. You don't wanna waste the 120+ dollars on annoying recurring holes in the side.
http://www.google.com/search?rlz=1C1CHMY_enUS340US340&sourceid=chrome&ie=UTF-8&q=vinyl+pool+patch+kit#q=vinyl+pool+patch+kit&hl=en&rlz=1C1CHMY_enUS340US340&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=y_38TZi-N7LTiAKQ7dmIBQ&ved=0CEoQrQQ&bav=on.2,or.r_gc.r_pw.&fp=731789854f5bd5b4&biw=1280&bih=685
Posted on Jun 18, 2011
briones93
  • 119 Answers
SOURCE: I have a 15x 42" intex metal frame pool an i also
Most likely you are not. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
Posted on Jul 23, 2011
I forgot to put one leg in the thick band of an intex pool, it is now full is this going to be a problem
They're designed to use all components shipped with the pool!
You make the decision, but I would say...
Put the other leg in!
Dec 28, 2014 | Intex "" Metal Frame Pool Set (56998e)...
I am getting a error code of 92 on my intex swg. I have put 4 - 40 lb bags into a 15 x 48 pool and brushed the bottom to distribute the salt evenly. I left the pump on for 24 hrs and then set the swg for...
I installed a new Intex ECO 8110 unit on my 15' above ground, steel sided pool. After about 10 hours of use I had the "code 92' high salt alert that shut the system down. I knew that my salinity wasn't high because the local Pinch A Penny pool store does free water analysis and i was given the okay just a week prior. We had also received a bit of rain in the interim so I knew that the alert was false.
Here is how I fixed the problem (so far).
1. Turn your unit off.
2. Disconnect the power cord from the outlet and wait for 2 minutes.
3. Unscrew the retaining nut at the electro-cell connector and unplug the connection.
4. Rotate the plug 180 degrees to reverse the polarity of the plug and re-connect to the electro-cell.
5. Reconnect the power cord to your receptacle.
6. Turn the unit on, wait for the green light to burn steady.
7. Monitor for the next 5-10 minutes.
My unit has worked flawlessly for 3 hours. If i receive another "code 92" alert i will repeat the procedure which will result in bringing the unit back to its original polarity.
Jul 01, 2011 | Intex Automatic Salt Water System for ...
Crooked ''legs'' intex pool
Jun 12, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Small tear in my intex pool
You can put a patch on the outside while there's water in it. What you do, is put a piece of plastic (bag, saran wrap, anything similar) on the inside to stop the leak while patching the outside. Place your patch with glue, then if you can, put a flat magnet on each side to hold it together and keep the plastic in place. Remove when it's cured, and it should hold you at least the season, when you can patch the inside.
Jun 01, 2010 | Intex Easy Set Pool 15x36
Intex pump 635 is a P.O.S.! How do I hook up a different pump?
I just left the standard intex connection on the pool and I cut the standard connection off of the filter side and I slid the hose over the top of a 1 1/2 pipe and put 2 stainless steel hose clamps over them and it worked fine
Jul 23, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Unlevel ground 3 inces
No, it wont collapse, if you fill it too full it will just overflow
May 23, 2009 | Intex Easy Set Pool 15x36
Pool & Spa Logo
89 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
