Question about Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX AMD Motherboard
No Beeps, Post, Nothing.
I installed my Biostar N68S3+ Motherboard to my new tower with all the components the same way as they were before in my old tower. I'm not sure about the preliminary (cables that came inside of the tower when I bought) being installed, or where the speaker connector goes on the motherboard, but I get no beeps, no posts on my monitor, everything powers up but I get no posts or image views on my monitors. They don't even pick up a signal.
  • 43 Answers
Make sure the p4 power connector is plugged in. (4 wire yellow and black wires) plugs in near cpu. Remove and reinsert memory modules. That is were I would start.
Posted on Oct 18, 2013
3 Suggested Answers
SOURCE: Only the cpu fan spins
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
If I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard lights are out and (wonder!) I can start the computer again in a normal way.
Can this one be a temporally solution for you too?
I guess that can be electricity dysfunction of a wrong fixed cable.
Posted on Nov 10, 2008
valeantudor
  • 787 Answers
SOURCE: Biostar p4m80-m4 motherboard stops during
The chipset i fried if you don't get any beeps at all. You'll need a new motherboard.
Posted on Feb 15, 2011
Biostar n68s3+ver:6.0 no power no power
CHECK ALL ELECTRIC WIRES MAKE SURE NOONE IS LOOSE.
IS THE WIRES OKEY,TRY WITH A OTHER POWERSUPPLY.
Oct 12, 2013 | Computers & Internet
Turn tower on it beeps 5 -8 times then nothing the monitor is on and says in powersave mode and to move mouse or keyboard to enable but nothing happens no lights on keyboard or mouse
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 12, 2011 | Dell OPTIPLEX 320 (MH651) Motherboard
Have a M7vig400 Mobo that is stuck at BIOS POST code 00 no beeps no video, any idea ?
Usually this means another hardware component has failed.
To troubleshoot, unplug everything from the motherboard except the CPU and memory to see if you get video.
Probably OK to leave the mouse and keyboard plugged in.
If still nothing, try removing one of the sticks of memory and then the other.
If you do get video, the primary culprit would be the CD and next the HD.
I'm assuming that the power supply is OK, but that isn't always so. I've seen computers that will boot but not correctly when part of the power supply goes bad.
Jun 17, 2010 | Biostar M7VIG400 Motherboard
Five beep post code
The beeps indicate that error is usually caused by hardware incompatibility or failure. More specifically check the following list:
You installed new hardware that is conflicting with old hardware.
There was a reecent electrical storm that caused a surge that damaged parts of the computer.
Try the following:
Remove new hardware.
Remove any disks or USB devices.
Remove any disks, CD's, DVD's that are in the computer and if any USB devices (ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes.
Disconnect external devices.
If nothing appears to work then try removing the ram and installing a new module.
Jan 28, 2010 | Abit NF-M2S Motherboard
No onboard video with my new MCP6P M2+ mainboard
Try removing the bios battery for 30 seconds then boot the pc, this will clear the bios. Maybe the bios was misconfigured. Else you can jump the "clear cmos" pins on your motherboard, same affect as removing the battery. If that doesn't work try different ram, it's possible the ram is not compatible. Sounds plausible being that there were no post beeps. Good luck.
Sep 14, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
Beeps when boots
Most likely a problem with your RAM.  Either it has gone bad or has been disconnected from the motherboard.
Apr 27, 2009 | Biostar U8668D (802700113338) Motherboard
Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX AMD Motherboard Logo
127 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
