Question about Mongoose 20 in. Boys Axe Bike
How do I make my bike faster - Mongoose 20 in. Boys Axe Bike
  • 700 Answers
Pedal faster...
beside that, you need to change your gear rose for different setup as well as sprocket. that meant you will need to spend few dollars on new gears to increase your speed.
this particular model is not designed for speed, it is designed for performance, like jump, slide, concourse, slalom, gravel, downhill - all of these are difficult to achieve on other types of bike, but that one is perfect for it, therefore i would suggest - do not pursue the speed but tricks on it, you will be envy of all neighbourhood...
Posted on Oct 20, 2013
MotoTec dirt bike has 3 setting for speed but each setting is under powered.. On high the bike might hit 10mph with 50 pound rider on asphalt.. Batteries are good and run forever on a charge. Fix?
You get what you pay for.
The setting for speed are 5,10,16 mph.
You want anything faster you would have to do major rewire of the bike to over volt and current on the motor and additional batteries - cheaper to buy a faster bike.
Sep 16, 2016 | Motorcycles
I have a 07 grizzly 700 4x4,when cruising at a steady speed you feel the bike surge,the faster you go the faster it surges,what could cause this?
Surging is usually at the throttles and idle air control motor. Cleaning them usually takes care of this problem. I haven't worked on bikes since the 80's. Surging back then was always dirty carbs. I am assuming that the new bikes are fuel injected and have an IAC motor.
Jul 30, 2016 | Cars & Trucks
Hey. I have juat bought a kawa zx9r. But the guy said he fitted an.other cdi so the rev counter dont work.. how do i fix it? Do i hve to replace the cdi to its original.one? Then the bike will be slower
Why do you think the bike would be slower? a cdi is mearly a box that regulates ignition pulses. There is no power to be generated here, unless you're flashing your ecu and re-mapping yout ignition table. Just run the original CDI. It's easier and cheaper to make yourself faster than your bike faster.
Mar 10, 2015 | Motorcycles
Honda shadow vt1100c 1986 idile to low after running awhile
There's an idle adjustment screw. The bike runs faster when cold because the fuel\air adjustment is richer on a cold engine. When the bike warms up, the fuel becomes more lean in mixture because the heat causes the fuel to expand, i.e., less molecules of fuel to the firing sequence of the piston. When the bike is warmed up, after say ten minutes, the heat causes a leaner mixture, so adjust the idle on a hot engine (about 1000 rpm more or less). The bike will idle faster when cold, then drop rpm's as the engine warms up. Good luck
Sep 17, 2013 | Motorcycles
I have a sakura s200 electric bike can i make it any faster ?
Change out the gears with a higher ratio that turns the wheels faster for the same motor RPM. Another method is find a motor that has a higher rpm capability.
Aug 23, 2012 | Electric Bicycle Motor, Bike,electric...
Why are road bicycles so much faster than hybrids? I commute in on a bog standard hybrid, and the guys on road bikes sail past me with what looks like minimum effort. I understand thats what they are...
Road bikes are faster due to their generally higher gearing and especially due to their narrower tires that pump to much higher pressures. Think of your bike like a boat. When you start a boat it gets up to speed and eventually is up on top of the water (what is called planing) and then you can actually reduce the throttle and mantain the same speed. In the same way narrow tire road bike riders can get their bikes up to speed and actually throttle back and keep the bike going at a similar tempo. The tires on a hybrid bike do not inflate to the 100-130 that many road bikes tires do. We used to have a pair of racing wheels and tires at my bike shop that we would let hybrid owners borrow. They could not believe the difference.
Dec 16, 2010 | Cycling
Mongoose 20 in. Boys Axe Bike Logo
62 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
