Question about Sharp XL-MP130 CD Shelf System
CD player fails to read CDs
Issue: CDs that are loaded into the trays do not read/play, even though they did previously. first it will happen with one or more trays, then more trays will go "unreadable" until none of the trays can play CDs. We have had this problem once before and called Sharp about it. They suggested unplugging the system overnight and then trying again. The other suggestion was to use a CD cleaning disk, which we did not try since the unplugging option worked. The problem with unplugging the system is that all of the preset radio stations, etc. are cleared from the memory. Not a real good fix, if you ask me. So we not have a <2 year old system that cannot be used to play CDs; we have reverted to casettes, if you can believe it.
  • Paul W
    Paul W Dec 30, 2008
    I've had the same problem. Cd's began not reading and over time it wouldn't read any of them. I just tried lubricating the motor, but i'm not sure where. i put a few drops of oil on the center shaft (below the top disk marked "Top"), allowing it to run down to the motor. i've also cleaned the lens and adjusted the eye in every possible position. most disks will spin a little while and then stop and the unit says "No Disk". any suggestions? can the drive motor itself go bad? if so, can it be replaced? for those of you who have lubricated the motor and found success, can you tell me exactly where you lubricated it? thanks!
The problem is drying lubricate oil fromelector motor which spin the cd disk.
Cool! It is real! Works great. After 4 days of f..ing around, finally works!!
Thank's a lot!
Posted on Sep 13, 2008
Hi Everyone !
We got the same problem two month ago and we fix it. The problem is drying lubricate oil from elector motor which spin the cd disk. You need to open top cover its 5 screw , 4 an sides and 1 on back. Then you see black cd changer in side. You need to open top cover of cd changer by unlock plastic clips and slide cover. Under cd holder you can fined elector motor that spin cd. You just need two drops of lubricate oil on top bearing at electromotor. My works fine right now .
Good luck.
Posted on May 23, 2008
I have the same problem. Actually took the cd unit apart and cleaned the lens but the problem still exist. Now here's the strange part... if I tilt the unit either to the front, back or side to side it starts working and keeps working even when I set it back level. But if I try to play anything else after I hit the stop button, I have to tilt it again. While I had it apart, I found out that happens only with the cd unit itself. As I'm not a tech, I know this may be a strange question but is it possible there's a "level sensor" (such as a mercury switch) causing the problem?
Posted on Apr 24, 2008
Did any one actually try to open and 'clean' the lens? Yo' Einsteins, The CD player is a SEALED UNIT! You cant get to the lens. My tech says they just replace it if the cleaning disk doesnt help.
Posted on Apr 02, 2008
Hi, This problem need an expert Technician, he should clean and tune the lens if it didn?t work it should be replaced. Good Luck Toufic Malek
Posted on Sep 28, 2007
  • 790 Answers
Cd cleaning disc is not advisable to clean your laser lens.. all you have to do is manually cleaning method! open the unit go to laser lens and clean it with 100% cotton buds then rub it slightly clockwise, but careful this is sensitive parts.
6ya staff
SOURCE:
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
Dec 03, 2017 | The Audio Players & Recorders
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
Changer will not pickup and play any of loaded cds. Just keeps cycling.
Hi! Your problem usually happens when the lens of the CD player is not successful in reading the Disc loaded on the tray. The problem could be due to a badly damage (scratched, warped or cracked) CD or due to a dirty/damage Lens.
You may first try to clean the Lens of your CD player and hopefully it would work. There are many good CD Lens cleaner on the market today.
Oct 06, 2009 | Audio Players & Recorders
American Audio Mcd-810 dual cd/mp3 player
i know its the tray belt.because,the same thing happened to me.my player would sometimes say error. or sometimes it would not read any cds.because,the tray would not close tightly.im shure its an easy fix.i did mine by my self.
May 31, 2009 | American Audio Mcd810 Dual Mp3 CD Player...
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
CD player fails to read CDs Sharp CD BA150 3 Disc Rotary Charger System : Issue; CDs that are loaded into the trays do not read/play, even though they did previously. Most disks will spin a little while...
This is a typical problem when the laser " eye" gets dust on it, unplug the unit and you can try to remove cover and spray the optical pickup "eye' with canned compressed air or other type of optical cleaner found at say like radio shacks, I have solved many disc reading errors with this method
Jan 25, 2009 | Audio Players & Recorders
Sharp XL-MP130 CD Shelf System Logo
1,196 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Pete Vernall
Level 1 Expert
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
