Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
I have a cooltech 700 and when i switch it on the display shows high pressure reseting, i checked the high pressure valve an it is all right, it has continuity between pins 1 and 3. what else can i do?
4 Suggested Answers
mhkamran
  • 180 Answers
SOURCE: Error Message: High Pressure Reset/Low Pressure Reset
Your machine may need to Calibrate pressure transducer or replace new one.switch ON the machine (FOR MODEL 34700Z) & follow on screen message.You can also try the following:1# Check recovery solenoid (S1) coil & make sure it's not burne or it's may need to rebuild.if so,replace new coil/rebuild solenoid flunger.2# Check inlet low & high side solenoids (small solenoids S10-S11-S13-S14) is receiveng power & opening properly.Hope this will solve your problem
Posted on Jul 27, 2009
mhkamran
  • 180 Answers
SOURCE: The high pressure unit is disabled in my Robinair
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
Posted on Jan 04, 2011
mhkamran
  • 180 Answers
SOURCE: Robinair cooltech 34788 displaced high
You Have to replace the PCB Relay Board
Posted on May 17, 2011
How to fix High pressure message error.
Seems to blockage in the inlet or pressure switch
Jul 01, 2016 | Robinair Cooltech 34788 R134a Automatic...
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
The high pressure unit is disabled in my Robinair Cooltech 34700z wat could be the problem?
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Why does the display show "HI" all the time?
This means that either there is a bad high limit switch, or you are getting a bad burn, or the pump is not moving water fast enough. With the power off remove the panel on the side above the plumbing.
There will be a pressure switch seated right on top of the header, then right below that, there are 2 high limit switches (1" round disks) Most typically, the pressure switch will start to leak and currode the contacts of the high limit switch, but some investigating will be necessary.
Dec 28, 2010 | Pentair Minimax NT Heater
AT MACHINE TURN ON DISPLAYS UNDER HIGH PRESSURE AND DISPLAY SAYS TO RESET WITH MAIN MENU BUTTON.BUT WILL NOT RESET
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just check the following :- 1# Verify the ISV tank is not overfilled.if full,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid & High pressure switch for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
Jul 12, 2010 | Robinair Cool Tech 34700Z Recovery,...
ROBINAIR 347002K WON'T INJECT OIL
I think you'v try to inject the oil from ''WRONG'' side,as you say RECOVER/VACUUM which is LOW side manifold valve. You should inject the oil from HIGH side ( Turn the high side valve to CHARGE/OIL INJECT after vacuuming & low side vulv to CLOSE possition ) with pressing F1 key. once you press it then hold the key as long as you wish to inject the oil. If you try this way & you still have problem with oil injection then you may need to check oil injection CHECK VALVE or oil injection SOLENOID ( Both located under Hidg side panel mountin valve). NOTE: UV Dye is not a problem for oil injection! I hope this will help you to solve the problem,Good luck. Don't forge to vote for my solution!
Jul 10, 2010 | Robinair Cool Tech 34700Z Recovery,...
Need location of HIGH Gear Pressure Switch on gm transmission
Do you have a 1 piece case or does the bell housing unbolt? A 700R4 usually has 3 switches on the back of the valve body.the one closest to the 1-2 accumulator (pass. side rear corner) is the fourth switch. If you have a two piece case, you have a 4L60E,the pressure switch is still on the valve body but it is an assembly,not a single switch.
Mar 30, 2010 | 1999 Chevrolet Silverado 1500
My washer starts and the water starts coming in, then it stops and an "F" shows on display and beeps...HEEELLLLPPPPP!!!!
Hi There
I want to say is Merry X-Mas and Happy New Year. I have found what you need hope this will get you in the right direction.
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Thank you for writing to fix ya. Let me know how it went.
Best Regards Richard
Dec 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My robinair isn't working and shows high pressure
This is a common problrm of Robinair 34700Z series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem.
Jul 12, 2009 | Heating & Cooling
Cooltech 700 display reads high tank weight resetting but machine does nothing else
Please do the following:1# With main power OFF,disconnect liquid line from ISV (internal tank) & press tank valve to reduce refrigerant manually as needed.2# Disconnect air purge line & reduce access air from ISV as needed.3# Turn main power ON & calibrate scal if needed.Hope this will solve your problem.
Jun 23, 2009 | Heating & Cooling
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
98 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
