Question about John Deere Eztrak Special Edition Kit Z425 Z445 Z465
I have a John Deere Z425 zero turn 48 inch deck, when I engage the blades it sputters and blades never engage
JD z425 zero turn mower. Shows error code 52E.
try a new battery after checking old one for voltage
Aug 13, 2016 | John Deere Riding Lawn Mower. EZtrak Z425...
How to injstalla48 inch belt
This link to replacing the drive belt on your mower should help.
http://manuals.deere.com/cceomview/OMM162472_J9/Output/Index.html?tM=FR
Oct 19, 2014 | John Deere Riding Lawn Mower. EZtrak Z425...
How to fit a 48 inch deck to john deere x110
Who told you that would fit? Take it back and get your money back.
Dec 13, 2013 | John Deere 22HP VTwin 48" Riding Mower
Z425 zero turn turns over but won t crank
I would recommend that you check your fuel filter to see if it is dirty/clogged, check you spark plug to see if it is getting fire. Replace either if needed. If you are not getting spark there are only a few things that it could be, either a coil, pick up coil, or magneto.
Mar 15, 2011 | John Deere 48" 65Bushel Zero Turn Tractor...
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Mower blades froze up
Have you greased the bearings on the mower deck recently? Is there something jamming the blades?
Remove the deck and see if you can move the blades by hand. If you insist on not removing the deck to do this ... make sure the belt that drives the deck is not on the drive shaft of the motor to prevent accidental starting of the motor and instant mangling of your hand. If you can move all the blades, look for a faulty or worn out pulley on the deck. If the blades are frozen in their bearings, get replacement towers at your John Deere dealer or from a FixYa.com advertiser. If one is faulty or rusted ... replace them all ... as they are probably at or near the same condition. Do this job one time and do it correctly.
Thanks for your support.
Thanks for your interest in FixYa.com
Please evaluate this response.
Thanks
Good luck with your repair.
Jul 05, 2010 | John Deere 24HP VTwin Hydrostatic 48"...
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
John Deere Eztrak Special Edition Kit Z425 Z445 Z465 Logo
43 people viewed this question
Top John Toys Experts
Vernon Taylor
Adam Fjeld
Adam Fjeld
Are you a John Toy Expert? Answer questions, earn points and help others
