Question about Sharp CD-SW340 Shelf System
How to take off timer with out remote - Sharp CD-SW340 Shelf System
Sanyo remote won't timer program
You must have its original remote control to adjust the timer recording.
Electro help
Jul 23, 2014 | Sanyo Televison & Video
I need to reset my remote start. My car is starting every three hours
Your remote starter is in timer mode. Pressing the lock and unlock buttons simultaneouly activates the timer mode. When you activate the timer mode the vehicle automatically starts every three(3) hours and runs the preset runtime for a maximum of six(6) starts.
You can cancel the timer mode by starting the vehicle with the key. If the timer mode is a problem then apparently you are setting the timer mode everyday.
Sep 30, 2012 | 4103P Python 413 Remote Start System with...
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
My remote only works on 1 and 2. # 3 does not work . How do I fix this?
You posted under Woods timers.
Woods makes a few different timers with remote.
One of them has 3 buttons
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
You can try unplugging all 3 remote units so they reset, and then try setting up on button #3 first.
You can also work around using this method: unplug all remote units. Plug in two remote units and turn both lamps ON. Then use button #1 to connect to both of those remote units simultaneously. This way, two different lamps can be controlled by one button.
If remote control is genuinely defective, then send it back for replacement.
Industry-standard is one-year limited warranty.
I own 2 sets of this timer.
One of the remote units stopped working immediately and has never worked since.
Both the remote controls work, but only 5 of the 6 remote units work.
I test timers and 6-8% arrive defective. Most go bad after a few years, some last quite a while.
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 24, 2011 | Woods Hardware & Accessories
Howto disable 24 hr timer in avital 4400
Remote start the vehicle; turn ignition on with the key. The parking lights will flash 4 times indicating that the timer mode has been exited.
Please note how the timer was activated by pressing the lock and unlock buttons.
When in the timer mode, the remote starter can time out or, you can shut down the remote starter with the remote and the timer mode will remain active. But, if the remote start sequence is terminated by any of the shutdowns ( ignition, brake, hood or neutral safety switch) while the remote starter is running, the timer mode will be terminated.
Feb 03, 2011 | AviStart 4400 2-Way Security / Remote...
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
How to set timer without remote
Nope, Im sorry to say you have to use the original for these functions to work. Go to http://www.remotes.com and get the proper remote.
Sep 27, 2006 | Toshiba MV13P2 13 in. TV/VCR Combo
Sharp CD-SW340 Shelf System Logo
21 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
