Question about GE Washing Machines
Spins only with light load - GE Washing Machines
    New Friend:
Check the belt assuming it has one, may be worn
Posted on Oct 18, 2013
Won't spin fast when fully loaded
You may have a weak clutch. If you can stop the washer during spin by hand, that's what it is.
Jan 26, 2014 | Kenmore 24422 Top Load Washer
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
Spin light flashhes spin does not work
The Miele W864 model will flash a warning light and will refuse to spin when it considers its load to be unstable....What I mean is... if you put a blanket in it and the blanket is on one side of the drum, the computer decides that if the machine spins, the centre fugal force or whatever they call it, the weight of the thing inside, will make the machine move about dangerously and will therefore not spin... its a safety feature. My spelling is shocking... I will look at the manual. Which says the load is unstable... more or less... waterlogged garments, like blankets can do this.... I normally just fill it with towels, and wash twice or three times because I wont get a good wash when overloaded.xx
Nov 12, 2011 | Miele W864 Front Load Washer
Spin light flashes & it won't rinse, drain or spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Will not spin, lock light out
heatman101
Jun 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Front Loading h2 (110.46462501). Was not spinning out water or going into high speed spin. Replaced belt (was stretched) and will spin out light load but not heavy. Tried heavier load and during...
I need to know specifically which lights are on...And if this is an HE2, He2 plus, or HE2T,,,
The lights give the error code to be certain... Also tech sheet behind front bottom panel will help identify error code and how to diagnose exact problem.
Mar 20, 2010 | Kenmore 46462 Front Load Washer
Washer will only spin with light loads. When
I replaced the clutch and the problem seems to be fixed
May 13, 2009 | Estate TAWS800JQ Top Load Washer
Wont always spin with a medium to heavy load
seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
Jan 16, 2009 | Kenmore 22622 Top Load Washer
Will not spin out heavy loads, stated by not balancing 2 mos ago
the transmission is shot after 20 loads a week for 4 and a half years
Oct 03, 2008 | Maytag PAV2300 Top Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
134 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
