Question about Maytag Dryers
Dryer stops mid cycle
The dryer mde2706ayw will dry for about half a cycle and then stop. We cannot restart it until it cools. this happens for any dial selection.
Do you have a blocked vent hose?
Posted on Oct 18, 2013
Testimonial: "I will be checking that tomorrow morning...we have a pretty long run and it's been a while since I have cleaned it out."
  • Greg Olson
    Greg Olson Oct 18, 2013
    Is this a pretty common problem?
hotuna
  • 288 Answers
SOURCE: Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Posted on Dec 23, 2007
  • 5 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Dry I, LEQ9508PWO
I would suspect the timer is on it's way out the door. Do you have any areas the timer has dead spots? Check the exhaust for any plugging also.Is this only on a first time start up or is it after this dryer has been running? If after running it could be a high temp sensor, that by the time you are playing around with it, the temp has changed.
Posted on Jan 25, 2009
  • 537 Answers
SOURCE: my dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Posted on Apr 18, 2009
erpaalai
  • 999 Answers
SOURCE: Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Posted on Jul 07, 2009
SOURCE: dryer stops mid cycle-restarts when cooled
Get a new dryer, no matter how old! My dryer was doing the same thing, stopping mid cycle, we went to turn it back on last night and it ignited inside. Called 911, got the kids out, fire contained inside the dryer, but damage around. We just had minutes before the flames got to the walls! Now I'm trying to figure out the best way to approach Kenmore/Sears for such a faulty product that could of cost our lives and home! It's a Kenmore from Dec 2001. 9 years old should not start on fire!
Posted on Jun 16, 2010
How to fix dryer that will spin but not dry
STOPS MID CYCLE AS IF AROUND 20-30 MINUTES? IF SO U MAY HAVE BAD MOTOR WINDINGS? OH OH, CAN CHECK HEATING ELEMENT AND THERMOSTAS WITH A MULTIMETER FIRST
May 12, 2014 | Frigidaire AGQ6700F / AGQ6700FE Gas Dryer
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
I have a Kenmore 80 Series Gas Dryer. We replaced the motor and blower wheel in October of 2010. Recently the the dryer has been stopping while drying clothes. No matter what cycle I put it on, it almost...
Hi, In looking at your problem please do the following. Go behind the dryer. The vent hose that is attached to the back of the dryer has to go straight to the wall outlet. It must not have any bends whatsoever. Its a straight shot to the wall. This should take care of it shutting off and being too hot. You may need, after the above, to change out the cycling thermo. Thanks for your inquiry and hope this helps. Have a Good Day!
Jan 18, 2011 | Dryers
GE dryer stops mid-cycle. If I try to restart it, it won't. Once I wait a few minutes for it to cool down, it will restart. I never know how long it run till it stops. A load last night stopped at...
I would say thermal fuse, here is a website that will tell you how to check, it also has other possibilities, Hope This Helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 21, 2010 | GE Dryers
Dryer stops mid cycle-restarts when cooled down--is it some sensor?
Good day,
Yes it's a sensor, but if you have to restart it manually after the cool down period, it is the sensor built into the motor.
That sensor measures motor temperature and current draw. It locks out the motor until it reaches normal temperature.
If it restarts on it's own, then post back with the complete model number. It would be a different problem.
Mar 09, 2010 | Kenmore Dryers
Tumble dryer will not dry
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 19, 2009 | Dryers
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Kenmore 11070702990 Gas Dryer - Timer does not work
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
133 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
