Question about Wascomat Parts Wascomat 231201 Washer NUT,M4 MINIMUM 5 PCS REMARKS - Wascomat Laun
Wascomat W640 Gets stuck about 1/2 way through the rinse cycle. I can hear water running through the middle hose in the back of the machine, but the cycle indicator just sits still indefinitely, and the tumbler is stopped. It's really confusing because the tumbler never fills with water, and I don't hear water exiting the drain... where is the water going, and better yet, why doesn't it ever resume?
  • Alan Edmunds Oct 19, 2013
    I have taken apart the washer since asking, I did find a large clog in the large rubber hose running to the back of the machine to the drain. Removing this did not fix the problem :(. This is a classic machine and the only "error code" is on a circuit board behind the compas dial. It is flashing all 3 red LED's in a pattern of 2 short blinks, pause, repeat.
    Oh and if I hit the cycle advance for like 3-4 seconds, it resumes, then again stops on the next rinse...
2 Suggested Answers
  • 19 Answers
SOURCE: My wascomat washer W125 every thing run good exception it not spin itself . Every begin time cycle spin I have to push the button on overload protect then it spin.
try replacing your timer on it
Posted on Oct 05, 2012
Testimonial: "Thank your solution . I replaced all component . I found problem in coil start of electric motor. Motor need rebuilding . Please help me where can repair motor. "
I have a maytag bravos x mct washer. It will not pump cold water the hot water comes out not the cold any ideas?
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
By the way my advice is free cuz God is good!
May 08, 2015 | Maytag Washing Machines
Rinse program not working
WASHER WILL NOT RINSE:
TIMER
Apr 30, 2015 | Washing Machines
Have a hotpoint aquarius wml540 that is stopping on the rinse cycle, when it stops the rinse light is on and the red lock light is flashing, is this an error code?
TIMER
Apr 07, 2015 | Hotpoint Washing Machines
Fix washing machine
TIMER
Mar 31, 2015 | Admiral Washing Machines
Amana washer will not go through rinse cycle
TIMER
Mar 28, 2015 | Amana Washing Machines
My washing machine mentioned above wont drain the water or preform the spin cycle process once it gets to the usual 7 minute mark. No leakage, just not drain or spin. How can I fix it?
TIMER
Mar 26, 2015 | Washing Machines
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
TIMER
Mar 25, 2015 | Bosch Washing Machines
Rinse cicle will not dispense water
TIMER
Apr 29, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Mar 10, 2009 | Asko W640
W640 - Water Outlet Fault
I solved this problem this morning, after several months with intermittent "water outlet fault" error messages.
Our pin trap was cleared many times over the months. The propellor turned freely. However, the problem persisted.
So I unplugged the machine, removed the back panel (8 or so hex screws) and located the point where the drainage hose meets the water draining pump. I then separated the hose from the pump and found 2 United States 10-cent pieces lodged together with gunk that effectively blocked the drainage hose. 10-cent pieces ("dimes") are the perfect diameter to get stuck there and not appear in the pin trap where you could easily see and remove them.
Three loads later, the machine is working according to spec. Hope this helps.
Apr 09, 2008 | Asko W640
Wascomat Parts Wascomat 231201 Washer NUT,M4 MINIMUM 5 PCS REMARKS - Wascomat Laun Logo
250 people viewed this question
Top Wascomat Parts Washing Machines Experts
Are you a Wascomat Parts Washing Machine Expert? Answer questions, earn points and help others
