Question about Radio Communications
Trying to get an MTS 2000 FLASHPORT to ride a primary channel and scan another channel
    Problem Solver:
  • 8 Answers
Program the scan list in the codeplug. This is a feature that must be programmed into the radio via the dealer programming software. By using the software the dealer will program scanning capabilities and then assign a button on the control head to turn scanning on and off. Every radio can have different features and functions programmed into the radio. If by pressing buttons on the face a "Z" like symbol apears, you've found your scan on/off button.
Posted on Dec 09, 2013
4 Suggested Answers
SOURCE: how to prograqm a motorola mts 2000 flashport?
1. Program the ABC switch as zone select.
2. Program each 'personality' into the proper zone (eg A1, A2..., B1, B2..., C1, C2..., etc)
3. Load the codeplug into the radio.
Posted on Jun 03, 2008
schast
  • 56 Answers
SOURCE: what are the button functions?
The buttons are programmable through the Radio Service Software (RSS) and can be used for any number of features. Some examples are Monitor, Scan, Repeater Access Tone (RAT), Light, Select, and the list goes on. Only reading the radio with the RSS can you be 100% sure.
A wealth of knowledge can be found at http://www.batlabs.com/mtsx.html as well as searching the forum located there.
Posted on Feb 12, 2010
Testimonial: "the orange button is the panic button. the green button on the side is the back light...the rest I will leave alone."
schast
  • 56 Answers
SOURCE: how do i program my motorola mts 2000 flashport
Your Motorola MTS2000 is not a scanner but a high-end two-way radio. It requires a computer, special interface box (called a RIB, for Radio Interface Box), the proper cable from the radio to the RIB, and the programming software called RSS (Radio Service Software.)
This is much more difficult than a scanner to program and if not done properly can cause the radio to automatically transmit on frequencies that you are not authorized to use.
Try calling your local Motorola dealer and ask them if they will program it for you for receiving only. They will either flatly refuse or they will be happy to charge you a service fee. Some places are more willing than others.
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
I need software for motorola mts 2000 flashport
You would need a programming cable as well. This is more likely than not beyond your current level of skill. This software is licensed by Moto, complex and not easy to get over the web. I suggest that first you sit down and make an outline of exactly what frequencies you want to transmit on if you are licensed and what to scan etc and go to a radio shop. It will be worth the money.
Aug 31, 2011 | Motorola HT1000, MTS2000, MTX8000/9000...
TV no sound but pictures ok, changed channels ok
The mts/sap function on your television might be enabled. Locate the audio settings on your television and make sure you are set for either stereo or mono. You may have an audio or mts button on your remote. If not this should be in the menu.
The cable company may have made a recent change and the tv may need to be channel buffered or you may need to complete another channel scan.
Aug 18, 2010 | LG 37LH55 37 in. LCD TV
What are the button functions?
Jan 30, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola MTS 2000
Motorola may be able to tell you if you call them, but they may refuse.
If your radio has a front display, you can put it into test mode to see what firmware it has. If it is 5.44 or higher, then it is FlashPort.
You access the service menu by pushing the button with two dots (on the side above the PTT) 5 times quickly after the power-up beep. If you have no front display this is useless.
Jan 01, 2010 | Radio Communications
How do i program my motorola mts 2000 flashport scanner
Dec 15, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Mts 2000 vhf constant tone
The scan is on and you do not have a scan list programed.
This is the most common problem connected to your post. Hope that helps, Bill.
Jan 02, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
How to prograqm a motorola mts 2000 flashport?
May 27, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Radio Communications Logo
79 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
