What's the tub size for a maytag A-211 - Washing Machines
    Habit-Forming:
  • 156 Answers
Which tub? You have the inner tub where you put your things to be washed, then an outer to that contains the water for the washing cycle. Which tub did you need the specs for?
Posted on Oct 18, 2013
  • 1 more comment
  • Laura jackson Oct 18, 2013
    Tub to wash in need cubic foot size
  • Michael Youngman
    Michael Youngman Oct 18, 2013
    3.28 cubic feet
    Thank you so much! My dad has this washer and it broke so I needed to know size so when we get a new one its the same or larger. Thanks again
My washer seems to leak between the tub and unit that snaps over the top
Your fill switch (that shuts the water off when it gets to the level set on the load size switch) is very likely defective. Contact a qualified Maytag service center for an appt to have the switch checked.
Apr 22, 2012 | Maytag Washing Machines
Drivers side brake light and horn won't work,,is it the multi function switch? 1999 chev blazer 4x4 . if so how much does a new one cost?
No there not connected, replace the brake light
1999 Chevrolet Blazer Auto Light Bulb Size Guide
Low Beam Headlight Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 3157
Front Turn Signal Light Bulb Size: 3157
Rear Turn Signal Light Bulb Size: 3057
Tail Light Bulb Size: 3057
Stop Light Bulb Size: 3057
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: 880 or 881
License Plate Light Bulb Size: 194
Back Up Light Bulb Size: 3156
Front Sidemarker Light Bulb Size: 194
Ash Tray Light Bulb Size: 161
Glove Box Light Bulb Size: 194
Map Light Bulb Size: 168 or 211-2
Step/Courtesy Light Bulb Size: 168 or 211-2
Trunk/Cargo Area Light Bulb Size: 211-2
Under Hood Light Bulb Size: 93
Instrument-General Light Bulb Size: 161 or 37 or PC194 or PC74
Check Engine Indicator Light Bulb Size: PC74
Hi-Beam Indicator Light Bulb Size: PC74
Seat Belt Indicator Light Bulb Size: PC194
Brake Warning Light Bulb Size: PC74
Automatic Transmission Indicator Light Bulb Size: 194
Directional Signal Indicator Light Bulb Size: PC74
As for the horn, inspect the fuse and relay and most common it would be a bad ground wire or worst a bad horn due to corrosion. Horn will be located in the drivers side fender.
Thank you for using fixya.
May 13, 2010 | 1999 Chevrolet Blazer
Leaking from bottom I think there is a hole in drum?
Not likely that there is a hole in the tub. The likely possibilities are a bad seal in the tub, a disconnected hose to the load size switch, or a leak in the drain hose or pump. Pull the front off and look for the leak.
Jan 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
I have a maytag performa top loading washer, model # PAV3240AWW, that overflows. It doesn't happen every time and it doesn't matter what size the load is or what cycle I am using.
You have sand and sediment in the sump base of tub. All you di is remove the rubber hose on the water level switch and blow out the tube with your mouth. You will feel it when the **** is out of there. Then reconnect that hose tightly to the switch and pump out any remaining water in the tub. here are some repair photos
Oct 08, 2009 | Maytag Performa PAV3200
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Water leaking on fill , fiil hose is not leaking , appears to be comins out under tub
either your tub seal is getting bad between tub and transmission or your "water fill" tube to the "size of load" water fill control on control panel has a leak in the plastic tube
Aug 25, 2009 | Maytag Washing Machines
Maytag washer will not fill
If it wont fill properly it sound to me me like a preasure switch. Take the control panel off and look at the load size selector switch (preasure switch). This has a hose connecting it to the wash tub. Follow that hose back to see if it may have some kind of blockage in the line. If not you may need to replace the switch.
Jan 26, 2009 | Maytag PAV2300 Top Load Washer
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Nov 20, 2008 | Maytag Neptune Washer
Maytag PAV2300 Top load washer
check your hose from the side of the tub all the way up to the water selector knob. if its loose or has even a pin sized hole in it, it will cause the maching not to sense it has reached the level selected.
Nov 29, 2007 | Maytag PAV2300 Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
