Question about Miller Hf 251D 042388 Tig Hi Freq For Engine Driven
Need to hook up miller high freq box to Lincoln ranger 10,000 generator it welds aluminum and works but no hook up point on welder for the 14 pt pin and it doesn't seem to be right wiyhout that control connection any advise please help
CarlGehrke
  • 169 Answers
SOURCE: hook up
I think I can help you do this, let's start with the general and you can ask questions if we don't cover everything you need.
The HF251D connects to the welding machine using 3 cables, you connect the Electrode terminal on the welding machine (the Lincoln) to the Electrode In terminal inside the HF251. Connect the Work terminal on the Lincoln to the Work In/Out inside the HF251, also connect the work (ground) clamp of your torch to this terminal. Be careful to select the correct size cables for the maximum current you intend to weld with.
The 3rd cable is the gray 14 pin round control cable that comes out the back of the HF251, it needs to be plugged into your Lincolns RMT14 socket. You'll also need to make sure that the Lincoln is set for remote control, this is usually a switch on the front panel. I'm pretty sure that the remote control cables have a standard pin layout, but we can check this by comparing the specs in both owners manuals.
After that you connect the torch and gas bottle to the HF251, start the Lincoln, and TIG weld until you're happy.
I've got a manual for the HF251 and can get a shop manual for it if we need it. What I'm not sure about is your Lincoln - what model is it exactly?
regards,
Carl
Posted on Dec 12, 2008
  • 3 Answers
SOURCE: welding aluminum
TIG weding is next to brain surgery as far as CLEAN goes.
You must get your AL clean, either by 1. Clean with a NEW Stainless Steel brush or 2. by using a chemical from the welding house that is made just for that.
Your cup must be clean and your gas flowing at the right amount,no leaks in o-rings or hoses.
Hold your cup more vertical and keep your filler rod in the gas shield always,no in and out movement.
In short you must get everything perfect to get quality Heliarc Al welds.
Good luck, HowardRoark
Posted on Dec 28, 2008
  • 14 Answers
SOURCE: what setting do I need to weld aluminum for a 135 miller mig weld
start slowly turning up the wire feeder,and the amps till you get the sound of bacon crackeling and youll know your there. hope this helps jojogunne
Posted on Mar 15, 2009
  • 24 Answers
SOURCE: Need wire diagram for Miller Syncrowave 250 DX
diagram is on the inside of cover or go to Millerwelds.com
Posted on Sep 18, 2009
SOURCE: Tig welder wont strike up arc, power to welder ok,
www.millerwelds.com › ProductsTIG -
www.millerwelds.com › Service & Support
Posted on Mar 27, 2010
I am getting no flow of fuel from the fuel tank to the fuel pump. Have installed new fuel filter and full tank of gas. Does this have fuel shutoff valve or a screen in the fuel tank.
[PDF]Ranger 225 Product Info - Lincoln Electric
www.lincolnelectric.com/assets/global/...1/e689.pdf
Lincoln ElectricENGINE DRIVEN WELDERS ... 50-225A DC 15-25V CV Welding ... RangerĀ® 225) for aluminum and other alloy welding. .... equipped with valve for gas flow.
Oct 09, 2015 | Lincoln Ranger 225 Engine Driven Welder...
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
I have a ranger 305d how can i set it up to weld aluminum?
You may not be able to unless it is DC voltage You need the special rods for welding aluminum but my understanding is it takes a DC welder to use them.
Mar 11, 2013 | Lincoln Electric Ranger 305D K1727-2...
Serial number miller AEAD 200LE JF 885778
Check this out:
http://www.ebay.com/itm/MILLER-AEAD-200LE-CONSTANT-CURRENT-AC-DC-ARC-WELDING-GENERATOR-GAS-POWERED-/310368057796?pt=BI_Welders&hash=item484360b9c4
Jan 13, 2012 | Miller Welding Tools
Welding fine , then machine quit welding, would still rev up, but barely arch!
I had the same problem except it was with a miller welder. it was a bad ground connection on the ground cable. if you have an ohm meter. turn off your machine,but do not unplug it. check for resistance from chassis ground on machine to input ground if your input on the machine is good you may have a bad cable,input connection or the ground clamp may not be making a good connection to the cable. good luck!
Dec 21, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
How do you hook a miller s-22p8 wire feeder to a lincoln ranger 10,000 plus engine driven welder?
you can't, the S-22P8 it's not a volt sensing wire feeder, it requires 24V or 115 with an adapter. FOr CV machines only.
Dec 08, 2010 | Miller Electric Mfg Co 903376 Deltaweld...
How too set up a tig welder for welding thin steel?
DC current, electrode negative (DC Straight, DC-), High frequency for start only (really don't have to use high freq at all for steel but it helps establish the arc without scratching), 1 amp per thousandth of material thickness is a good setting to start, adjust from there for the job. 1 amp/thousandth also applies to aluminum- it has a lower melting point than steel but conducts heat much better so power to weld is very nearly the same.
Use a sharp tungsten, don't ball it at all (as you would for AC work).
lp
Dec 01, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Tig will work normally on aluminum for a few minutes then will cut out and the only way to start it again is to scratch start it but then it will only work for a little while
this seems to be a duty cycle of the type of welder you may have,the other thing im thinking you need to be in continious cycle mode ,theere should be a switch allowing continious cycle also the main switch should be on ac mode for welding aluminum. the tungsten should be 1% with a green paint on the end .you mention you have to scratch to restart the welder you have might need a high frequency box of its own that also hooks to the welding machine, small amp welders have small duty cycle which means it will shut down if its getting over worked or hot good luck
Jul 31, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Hook up
regards,
Carl
Dec 10, 2008 | Miller Hf 251D 042388 Tig Hi Freq For...
Miller Hf 251D 042388 Tig Hi Freq For Engine Driven Logo
80 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
