Question about GOG Paintball GoG eXTCy Paintball Gun - Silver
My gog extcy will not shoot i have a full battery, full gas tank its on and ive tried adjusting the velocity.
My compressor only builds 100# of pressure...it is adjusted all the way in and still only builds that pressure
Check for air leaks or possibly the filter needs cleaning. Also make sure the tank is not partially full of water. The engine may not be generating enough power because of wear. Please Read the following for more info.
Air Compressor Trouble Shooting Guide
Mar 25, 2016 | Air Tools & Compressors
Gas tank will not fill up on 2001 ford expedition
Gas as in gasoline or gas as in LPG gas? If its petrol, the fuel sender may be out of adjustment. (Usually means a new sender) If its LPG, the fuel stations are set to automatically shut off at 80% full. The gas tank will never actually be full to the brim but the gauge should be showing full if the gas nozzle keeps shutting off. Have a look on the LPG tank itself, they have a little gauge on them which shows how full it is. I have 2 tanks on my car , when "full" or when the pump shuts down, the tank gauges show just under full but the gauge on the cars dash shows full (2005 BA Ford)
Feb 18, 2015 | Ford Expedition Cars & Trucks
Gas tank wont allow me to pump gas into it with out back splashing
Usually a sign of a problem with the gas tank vent or a restriction in the fill tube going down to the tank.
Apr 08, 2013 | 1999 Ford Expedition
How to set velocity on tippnan 98 custom
There is a velocity adjuster on the left side of the body, just below and to the right of the "N" in "TIPPMANN."
In order to adjust the velocity you need to be in a place where it is safe and legal to fire your marker (paintball field, with all bystanders protected by netting or paintball goggles.) You will need a chronograph and a 3/16-inch hex wrench.
The adjuster is a screw that blocks the gas flow from the valve to the bolt. If you screw it in (clockwise) it blocks more of the gas, so your velocity goes down. If you screw it out (anti-clockwise) it blocks less gas, so the velocity goes up.
Just take a shot over the chronograph to check your velocity, adjust and check again until you get it where you want it. Most paintball fields limit velocity to 285 feet per second. Never go above 300 feet per second, as velocities above that are unsafe (beyond paintball goggle ratings and can cause damage and infection on skin due to the heavy impact.)
It is important to test and adjust the velocity before each day of play, and even multiple times during the day as weather changes, because it is affected by temperature.
Jan 19, 2013 | Tippmann 98 Custom Act Paintball Gun
AFTER I RUN MY DIAMO VELOCITY 50 FOR A LITTLE WHILE IT STARTS CUTTING BACK ON ME. I'VE CHANGED THE GAS 2 TIMES.I'VE TAKEN THE INTANK FILTER OUT AND IT LOOKS GOOD. THE PUMP PUMPS GAS WHEN I TAK
Hi, Robert11 if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 3 years or older when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and replace the battery.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove your air cleaner and clean and re-oil per Mfg. specifications.
6. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
8. Replace spark plug with a new one and check for spark.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
TROUBLE SHOOTING
http://www.carlsalter.com/diamo-service-manuals.asp
Scooter Parts for Chinese Scooters Atvs
Chinese ATV Owners Repair Manuals
Diamo Velocity 50 2008
Oct 04, 2012 | 2008 Diamo Velocity 50
I CAN'T PUT GAS IN MY 2003 LANCER
Your evap charcoal canister is full from being overfilled. The biggest problem with "topping off" is that it can wreck the evap system.
This system collects gasoline fumes from the tank and routes them to the engine for combustion.
Overfilling could force raw gas to enter the system and prevent it from working right. It could also cause a condition where you have a hard time filling the tank, as the system can't properly relieve pressure from the tank and the gas pump's automatic shutoff keeps engaging.
You will need to replace the canister for the fix.
Thanks for using FixYa - a FixYa rating is apprecited!!
Feb 23, 2009 | 2003 Mitsubishi Lancer
Pontiac 2003 Sunfire Gas Guage doesn't work
Your needle moving from empty to full and then back to empty indicates that it is trying to set itself (most cars do this each time they are started). So, yes, there seems to be a problem with the sending unit that feeds information to your gas guage. Prior to cracking open your fuel tank, you might try tracking the wires from the back of your guage as far as you can towards the tank. Then track the wires from your tank as far as you can toward the guage. Watch for damaged wires and/or loose connections as you go.
Jan 29, 2009 | 2003 Pontiac Sunfire
GOG Paintball GoG eXTCy Paintball Gun - Silver Logo
51 people viewed this question
Top GOG Paintball Video Game Consoles & Games Experts
James Wishart
Are you a GOG Paintball Video Game Console and Game Expert? Answer questions, earn points and help others
