Question about ASUS Computers & Internet
Error code 301 - ASUS Computers & Internet
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: error code 301
The IBM error 301 POST code means the keyboard is not responding correctly.
You could have a stuck key, or the keyboard cable is faulty and not making proper electrical contact.
You could have a faulty keyboard controller.
You may have a faulty keyboard which may had some fluid spilt on the keys.
Try clean and reconnect the keyboard cable.
If this doesn't work try connecting an USB keyboard and see if this keyboard functions correctly.
If none of these work you have a motherboard problem. The Thinkpad 600 is a very old laptop and it would not be worth fixing. I suggest putting your money towards a new laptop.
Posted on Jul 12, 2009
Error code 005-301
Please try the following
- Lift the cover to expose the flat bed scanner glass.
- Under the cover, there is a long white bar with two white tabs perpendicular to the white bar.
- One of the tabs could be retracted. Pull on the tab until it is fully extended.
Error "Cover Open 005-301 Close ADF Cover" and solution is Close the cover of the ADF
Jul 23, 2014 | Dell 3115CN
Ford error codes p0172
0172 rich fuel
301 misfire on #1 cylinder
Apr 06, 2014 | 2005 Ford Taurus
Error code 301-0001 on i-sensys MF 4450
Show error code 301-0001 after press (Problem with Canon i-SENSYS MF4140 All-In-One Laser Printer
Error code 301-0001 on i-sensys MF 4450cont: 8016185745-dulal
Nov 27, 2012 | Canon i-SENSYS MF4140 All-In-One Laser...
2005 Grand jeep 4.7 error code 301
Code 301 is for a miss on cylinder one, which could also be caused by a problem with the injector or a vac leak among other things.
Jul 27, 2012 | Jeep Grand Cherokee Cars & Trucks
Canon image class mf4412 error code 301-0001
good affternoon i want the salution of canon printer 301-0001 eror
Mar 27, 2012 | Canon Office Equipment & Supplies
MEIKO DV 80.2 ERROR CODE 305
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
Mar 23, 2012 | Meiko DV 80.2 Dishwasher
What are error codes 801 301 3D and 800 1000A on the Sony Playstation 3 console. I need help realy bad. Enyone that awnsers will have there questions awnserd. Thanks for reading.
Error 801 301 3D is due to internet connection issues.
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. ps3 , use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
And 800 1000A error means that you cannot download from the sony store. hence the connection problems from your first error.
Hope this helps you.
Correct? recommendation and vote would be aw some!
thanks.
Nov 22, 2010 | Sony Playstation 3 (PS3) Console
Error 301
that code is related to the scanning lamp
Mar 22, 2010 | Canon imageRUNNER 400S Copier
WHIRLPOOL AKR 301 IS FLASHING O3 F Fault code
Jan 09, 2010 | Cooktops
Error code 301
Jul 12, 2009 | IBM ThinkPad 600X Notebook
Computers & Internet Logo
13 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
