Question about HP LaserJet Pro P1606DN Laser Printer with Auto Duplex Printing
HP P1606dn printer toner light is on. I installed new toner but it still is blinking.
    Master:
  • 511 Answers
Improperly installed, dirty sensor contacts,
Posted on Oct 20, 2013
It needs a new cartridge
Feb 25, 2014 | HEWLETT-PACKARD LASERJET PRO P1606DN...
CE749A not discovered during install
Verify that the network station cable (the one connected to the P1606DN printer) is good and that the connection to the network is good. You can do using a number of methods. But, if you have a portable computer, the simplest method is to disconnect the cable from the P1606DN, connect it to your computer (make sure the wireless on your computer is turned off), and verify that you can connect to your network. If not, you have a cable/network problem.
Otherwise, try resetting your P1606DN printer to its factory defaults:
1. Turn off the printer
2. Turn the printer back on, and while it is initializing press and hold both control-panel buttons at the same time until all the lights blink in unison.
Then put your static IP address back on the printer and hopefully you can now connect. If not, can you ping it from a workstation? If not, the network adapter circuitry in the printer may have failed.
Feb 02, 2014 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Hp laserjet P1606dn network adapter: no green
is it red... if no colour the wifi card has either come loose or not working any more.
Nov 03, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
HEWLETT-PACKARD LASERJET PRO P1606DN PRINTER
the cartridge in this machine has a chip on it but it should still print if you get a toner low message. the chip counts pages not amount used to print so if you are doing light print jobs it does not no it only counts the cycles
Mar 13, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
My hp laser jet printer p1606dn is printing vertical lines n the left of the document and its missing all the left side of the doc
From this limited information, I suggest you remove the toner cartridge and tip it left to right several times to re-disperse toner. Put it back in place and try printing again. If the doesn't work, your toner is likely low or empty.
Mar 09, 2013 | Office Equipment & Supplies
My printer had the toner light flashing I replaced the cartridge with a new one but the light is still flashing. What do I look for now?
did you replace orginal HP cartridge? if you are change refill or any other kind of manufature cartridge , there is chip is not working properly, that's why ligh is blinking, use orginal HP toner or good quality brand
Dec 01, 2010 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Toner light keeps blinking
The inkjet uses ink, not toner. When the light is blinking it indicates something is wrong with one of the cartridges, such as can't find it, not installed, out of ink, improperly installed, printer has died. First thing to try is to disconnect the power (not just power off) for 5 - 10 minutes and reconnect. If that does not resolve it, inspect the cartridges and reinstall them. If you have another printer that uses the same cartridges, try the cartridge in it. if not, get another set of cartridges and install them. If none of these steps resolve the problem, chances are that the printer is the problem and is probably not worth spending additional time on it.
May 03, 2010 | HP DeskJet 810c InkJet Printer
Just changed TONER & it still flashes NEED TONER.
have you removed the plastic strip from the toner which secures your toner.
Feb 17, 2010 | HP LaserJet 1320 Printer
Blinking Cartridge Light HP Laserjet 1500L
the cartrige has a micro chip on it which resets the toner level.be sure that your non hp toner has this chip on it
Feb 03, 2009 | HP LaserJet 1500L Printer
Toner light still blinking orange after new toner installed. Rebooted printer, light still blinking.
It means you need to replace the photoconductor kit (the bit the toner fits into) reset information is supplied with the new photoconductor kit.
Oct 15, 2008 | Lexmark E232 Laser Printer
HP LaserJet Pro P1606DN Laser Printer with Auto Duplex Printing Logo
Seeker5211
Seeker5211
