Question about ClickFree HD325 320 GB USB Hard Drive
Faulty circuit board of clickfree hard drive hd325. Where to find the board. Pls! Help!
    Novelist:
    Scholar:
  • 100 Answers
This is en external HDD. This means, there's a HDD inside the package, and a small PCB (print with tiny ICs on it). If you're lucky, the PCB is defective, while the HDD is OK. In that case, you only need to look for another USB Harddisk enclosure for a 2.5 inch SATA harddisk. Maybe your local computer-store sell these casings, otherwise check internet (eBay for example)
To be sure it's either the HDD or the PCB, just open up the casing and remove the HDD. Insert this HDD into a PC, connecting it to the motherbord over a SATA-cable (and don't forget to use a powercable too).
If the HDD becomes visible under Windows or whateven operating System you use, than it's indeed the PCB, which is defective. If the HDD is not visible, maybe the HDD is defective. In such case, you can find at internet a new(er) HDD of identical make (brand / type HDD)
Posted on Oct 18, 2013
How do I retrieve my information from a Clickfree backup harddrive that is no longer working?
the clickfree hard drive is the same as any other hard drive and when it fails it has lost everything
there are computer shops that may be able to retrieve the data on the disc but you will have to ring around to find one
try places on the net
Jan 09, 2016 | ClickFree Computers & Internet
Windows 10 does not reconnizes clickfree
FIRST CONTROL THE USB CONNECTORS
SECOND USE IN ANY CASE A LINUX LIFE CD/DVD/ USB TO MAKE YOUR PC BOOTABLE IN A LIFE DISTRO TO SIMPLY CONTROL THE USB PORTS AND THE DRIVE. BECAUSE THAT WILL ALWAYS LET SEE YOU THE DRIVE IF ITS IN GOOD CONDITION..
Dec 19, 2015 | ClickFree HD535 hard drive 500 GB USB
Clickfree cannot be fixed because of an I/O device error
Not much you can do except sending it to Clickfree.
Aug 31, 2014 | ClickFree Computers & Internet
Circuit Board of my ClickFree Hard Drive Model # HD325 is defective. Where to find a replacement? Please! Help!
When you opened this enclosure, you probably noticed the harddisk inside. If it is the circuitboard of this harddrive which needs to be replaced, you should look for the manufacturer of the hardddisk (Seagate, Western Digital, Toshiba, or Samsung) , the type of harddisk and it's manufacturing date. With this data you can try to find a used harddisk at i.e. eBay.
When it's just the circuitboard of the enclosure, which connects the harddisk to your USB-port of the PC, you're more lucky, since you can buy for about 15 USD a new USB-enclosure at i.e. eBay incl. shipment.
Oct 18, 2013 | ClickFree Computers & Internet
Clickfree C2N Won
IF IT DONT WORK MAYBE YOU WILL NEED TO REFORMAT IT.IN THE PROCCESS YOU WILL LOOSE ANY DATA ON IT.
PLUG IN AND FIND IT THEN RIGHT CLICK AND SELECT FORMAT
Apr 10, 2012 | ClickFree 500GB Clickfree C2 Portable...
Clickfree hd 735 manual
Clickfree hd 735 is an external hard drive backup solution. The manual can be downloaded here.
Jan 09, 2012 | Cameras
Trying to run chkdsk on clickfree c2 500gb
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
Jan 01, 2012 | ClickFree 500GB Clickfree C2 Portable...
I need to format my HD325 click free for mac
I'm sure the OP no longer needs to format their Clickfree C1 HD325 for use on Mac OS X, but I'll answer this question for anyone else who may need a solution.
Before you begin, there are a few things that you should know about Clickfree C1 and Mac OS X compatibility:
-Most Clickfree devices are compatible with Mac OS X 10.5 or higher, but there are some Clickfree C1 devices that aren't compatible with Mac OS X. If your Clickfree C1 was manufactured prior to 2009: your Clickfree C1 won't be compatible with Mac OS X.
-Take a look at the label located underneath the Clickfree C1: if you see WD08xxXM (WD08 is what's important here, you can ignore the rest of the numbers/letters that follow), your Clickfree won't be Mac OS X compatible.
-Formatting the Clickfree C1 using HFS+ will prevent any Windows operating system from detecting the Clickfree correctly. Try formatting the Clickfree in NTFS from a Windows computer for compatibility with both Mac OS X and Windows.
Pre-requisites:
-A Mac using OS X version 10.5 or better
-Administrator rights
Try the following steps to format your Clickfree C1 for use on a Mac (note that this will erase the contents on your Clickfree C1):
a. Using your keyboard, press the option key + command key + spacebar at the same time; a finder window will appear
b. In the search field located at the top-right of the window, type: Disk Utility
c. Finder will perform a search, and will display the Disk Utility application icon; double-click on the Disk Utility. The Disk Utility application will start
d. Plug your Clickfree into USB, wait a few moments for the application to recognize the Clickfree
e. Click on Clickfree Backup Media from the left side of the Disk Utility window
f. Select the Erase tab
g. Click on the Volume Format drop-down, select: "Mac OS Extended (Journaled)"
h. In the Name field, type: CF_Storage
i. Click on the "Erase" button.
j. Once the erasing is complete, close the application
k. Unplug your Clickfree from USB
l. Plug your Clickfree back into USB
Sep 03, 2011 | ClickFree HD325 320 GB USB 2.0 Hard Drive
When I delete from the Clickfree Harddrive I do not get back space on the harddrive. Instead, the deleted information space is now called OTHER. I want to know how to delete things permanently so that I...
It sounds like you want to wipe/format the drive COMPLETELY. There is a very helpful page at this link: https://www.cnet.com/forums/discussions/how-can-i-format-a-clickfree-usb-hard-drive-514102/ from C-Net that has a discussion on the topic in various operating systems. Be sure to read the entire page, as some contributors enhance other's solutions. This may help. In case I miss your intent, there is a document on the use of Click-Free drives (PDF) located here: pdfstream.manualsonline.com/4/42f5792a-0734-4e95-bd37-e0474cabc1ee.pdf . Good luck, write back if you solve this or need more help.
http://pdfstream.manualsonline.com/4/42f5792a-0734-4e95-bd37-e0474cabc1ee.pdf How can format clickfree USB hard drive Forums
Dec 24, 2017 | ClickFree Electronics - Others
ClickFree HD325 320 GB USB Hard Drive Logo
87 people viewed this question
Top ClickFree Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Joseph Wright
Are you a ClickFree Computer and Internet Expert? Answer questions, earn points and help others
