Question about Gateway FPD2185W 21 in. LCD Television
My Gateway FPD2185W TFT LCD Monitor has the VGA symbol that would stay on the screen for 30 seconds and disappear. Now it stays on the screen and the only way to get rid of it is to disconnect the power supply to the screen and it goes away until the next time it goes to sleep and then back at square one. For awhile i could hit the menu button to make it go away but that doesn't work anymore.
  • 3 Answers
SOURCE: FPD2185W turn on problem
I had a similar problem... mine would work fine all day. I put it to sleep at night and when I go to wake it back up, it would come on for a second and then back off.
Here's my fix:
BE CAREFUL when popping the case open and unplugging the connectors!
Everything is flimsy and can break easy. TAKE YOUR TIME, and be very gentle.
Ikeep electronic screwdrivers, tweezers and the like for projects likethis. The connectors were a b*tch to get out. They are darn-near microscopic, so take your time and skip that next can of beer... you're going to need patience and concentration to get the little bastards out.
OnceI got inside, I found the capacitors were NOT bulged out the top,leaking, or leaning; however I noticed some of the bottoms on the canswere sticking out further than others.
Hard to say if they are bad, but it won't hurt to replace them since I'm already knee-deep into it.
There are 14 capacitors total that I replaced. You might as well do all of them.
Ok, now time to find the replacement parts:
Thenew capacitors were a bit of work to find. My local Radio Shack andtheir online store didn't have some of them, and the ones they didwasn't rated the same.
The OEM capacitors are rated 105* (1000hrs). There were a Samxon brand. According to some web sites, thesecaps are a general purpose and a lower-quality cap.
The Radio Shack ones are 85*. They would probably work, but who knows for how long.
Ifigure the OEM caps are already made by the lowest bidder, so I betternot take the chance and make it worse! Besides, Rat Shack didn't evenhave all of them.
Here is a list of the caps I found in mymonitor (your monitor may be different and you should check yoursBEFORE you order them)
* ALL OF THESE ARE RADIAL ELECTROLYTIC (aluminum can type), 105 deg. *
QTY. (1) 10 uf, 50V
QTY. (1) 47 uf, 25V
QTY. (2) 68 uf, 450V
QTY. (2) 220 uf, 25V
QTY. (8) 470 uf, 25V
I found all of the parts at Allied Electronics: https://www.alliedelec.com/
Total parts was less than $8.
Allied part #'s:
10uf: 613-0743
47uf: 613-0783
68uf: 613-0312
220uf: 613-0766
470uf: 613-0190
According to their specs, they are good for 2000 hours.
Digikey also had them: http://www.digikey.com
Theirprices were comparable, but I couldn't get all of the same manufacturer(not that it really matters, but I'm picky like that :) )
I took my time and I was up and running in about an hour. Most of the time was spent removing the old caps. They can be a real bear to get out if they have the sticky goo under them.
So far the monitor is running perfectly. Only time will tell if I get the power-up problem again.
Hope this helps.
H.
Posted on Oct 01, 2008
bammbammfran
  • 159 Answers
SOURCE: Screen only stays on for 1 sec
Assuming you changed all the caps and did it correctly.
IF you get flickering, It could be a transistor on the inverter board.
OR !!! and probably more likely,
It could be one of the bulbs in the lcd itself is failing. It only takes one bad bulb to stop an inverter from firing up !! You can check them one at a time if you have another working monitor.
If you do unplug a good bulb from the good monitor and try each of the questionable ones, one at a time.
Doesn't have to be a gateway monitor to test it, just needs the same backlight plug.
ebays bammbammfran
Posted on Oct 06, 2008
  • 191 Answers
SOURCE: Gateway FPD2185W monitor turning on problem
change ur inverter
Posted on Nov 10, 2008
SOURCE: Gateway monitor fpd2185w goes to sleep and then shuts off
I suggest to mess around with the monitor buttons and see if you can disable it from sleeping from there. If not then try enabling it to sleep on your computer settings. A good restart after any changes is always helpful.
Posted on Jul 08, 2009
saberdog
  • 5 Answers
SOURCE: My gateway FPD2185W monitor image on the screen is
Press CTRL+ALT+UPARROW
Posted on Feb 12, 2010
When i plug in my Gateway FPD1975W TFT LCD Monitor, the screen stays black and the power button blinks. This goes on for hours without doing anything else. Suggestions?
If you have this connected to a computer and it happens,make sure the fault is not with the graphics card or port first. Test the monitor on another computer or laptop. Test and check the VGA cable.
If this is not the problem (ie the monitor will not work on another computer and another monitor will work on your computer), you are probebly having power capacitor problems and the monitor needs replacing.
This link will explain more
http://en.wikipedia.org/wiki/Capacitor_plague
View sonic monitors were particularly known for this problem
Aug 16, 2011 | Gateway FPD1975W 19" LCD Monitor
My screen turns black upon startup. For awhile when my screen was on, it would flicker on and off but remain on. Now, the only time I can see the screen is when I unplug vga cable then plug back in but...
You mention a VGA cable so I assume its a stand alone monitor for a desktop PC.
It can be repaired,this fault is usually indicative of a capacitor, maybe two or three bursting in the
a) Power supply.
b) Back Lighter.
or
C) Inverter.
As its 6 years old, I would suggest replacing would be the most cost effective resolution.
Jun 10, 2011 | Gateway Computers & Internet
Gateway FPD2185W TFT LCD MONITOR
The backlight or inverter is going out on your screen.
Eventually it will just stay dark. You will need to replace one of the two if plan on keeping monitor.
If you find this helpful please rate so.
Thanks
May 04, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
FPD2185W Gateway monitor
If they dont due anything Contact Monitor Depot Link was below BBB they fixed mine for 99.95 works great Let me know how it turns out
Oct 24, 2008 | Gateway FPD2185W 21 in. LCD Television
Gateway fpd2185w tft lcd monitor repair
Probable failed power supply. If you look at the screen on an angle after your system has finished booting and see faint images, it is the backlight or is associated high voltage power supply that has failed.
If you see no 'shadows' at all, then the main supply has failed.
Either one of these could be a separate supply since many manufacturers buy from specialized companies.
Aug 24, 2008 | Gateway FPD1975W 19" LCD Monitor
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
61 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
