Question about GE Ovens
Fo code oven model jrso4bow5bb - GE Ovens
  • Arne Christiansen Oct 19, 2013
    I have changed the erc board now I'm wondering if it's the key panel and is there a good way to check it before handing over 400 dollars for a new one?
2 Suggested Answers
SOURCE: Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Posted on Nov 22, 2009
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
FO ERROR ON OVEN
Seems F0 is a problem either with the control panel or with the key panel
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You can go to this site to find replacements
Mar 14, 2008 | GE Profile JKP56 Electric Double Oven
FO error code
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
May 06, 2010 | Magic Chef 9122 Gas Single Oven
FO shows on led board for both ovens
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
NOTE_ Some models incorporate the touch/Key pad into the EOC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the EOC (Clock).
Nov 06, 2009 | GE Profile JT952 Electric Double Oven
Jun 28, 2009 | Ariston Technologies Ovens
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Fo function error code
The F0 usually means that there is a problem with the keypad.
My solution for the F7 problem may help. You will find my solution at the following link.
http://www.fixya.com/howto/h155050-dreaded_f7_error
I have now shared my fix with over 1600 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Charlie Popeck, P.E.
Consulting Engineer
Mar 07, 2008 | GE Profile JKP56 Electric Double Oven
Ovens Logo
70 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
