Question about Whirlpool 3362624 Washer Control Timer Knob
Need new cycle control knob for Whirlpool Model LLR8233BNO
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
You can order replacement parts online. Here is a site that I have used in the past.
http://www.appliancepartspros.com/top-cabinet-parts-for-whirlpool-llr8233bn0.html
There is a place to search within this model and if you type "knob" without the quotes, it will show you just the knobs for the washer.
Posted on Nov 27, 2013
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool Duet GEW9250 Dryer; Only Running in Delicate Cycle
that knob is actually a switch. fixing it will be much easier, if you replace the whole switch unit..
good luck..
Jan 29, 2008 | Whirlpool GEW9250 Electric Dryer
Where can I buy a new cycle control knob for my Whirlpool Model LLR8233BNO washer?
Hello Penny New. To view the parts list for your model, please use the link below.
https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20881070.pdf
Thank you, Ashley
Oct 18, 2013 | Whirlpool 3362624 Washer Control Timer...
Washer will not start
I know how frustrating it can be when appliances do not function properly.
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
Activating the service diagnostic modes.
You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc...
If there are no error codes stored, you will need to replace the control board. Here is a link to the part.
Oct 17, 2012 | Whirlpool Washing Machines
Model # LSR5132PQ The front part (white and gray) portion of the Cycle Control Knob falls off.
There are four different styles on this machine LSR5132PQ 1-4. I would recommend looking at the parts diagram and purchase the switch behind the panel and the knob.
That will fix it.
Joe
look up you parts here
Feb 19, 2011 | Whirlpool 3362624 Washer Control Timer...
The control switch on the top right to operate the wash/ spin cycles doesnt want to engage unless you jiggle it into place, does it need a new control knob or is there an assembly that needs replaced
This would be the control that is located behind that knob, the part is called a timer. The part number for you machine is 3951702 if you model number ends in 0, 1 or 2. 8546165 if your model number ends in 3. The model number is located on the top near the back of the opening where you load the clothes, it is visible when you open the lid. The part is about $70.00
Here is a picture showing the timer, it is part number 9 in this drawing.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0207069-00002.png
Apr 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer skips cycles only works when you touch knob
You will need to renew the control the knob is connected to.
Nov 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T...
Hello dacarle,
Welcome,
You said, I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T START.
Please send me the model number so i can check out the problem.
Waiting your response
Huuum
Oct 15, 2008 | Whirlpool Dryers
Whirlpool 3362624 Washer Control Timer Knob Logo
75 people viewed this question
Top Whirlpool Hardware & Accessories Experts
Joseph Mueller
Joseph Mueller
Bill Boyd
Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
