Question about Compaq MP2800 Microportable Projector sps Projector Lamp
InFocus X2 Projector Fault
I have several Infocus X2 projectors. One has started to produce a dark blurred strip down the left hand side of the screen. (A similar effect can be produced by putting your finger close to the lens, blocking the edge of the picture. The inference is that something has come loose and is blocking the light path (Infocus told me that!) I have managed to take the whole projector to bits (and put it back again!). I have cleaned out everything with an air duster and can find nothing loose or stray. The picture is now very slightly better. I'm reluctant to take the chip mechanism apart. Any suggestions?
  • djmystro Apr 01, 2008
    I also have the x2 Infocus Projector and getting a dark strip on left side ....trying to find a repair station here in the Houston area any help out there would be greatly needed..Thanks in advance....
  • Anonymous Jan 26, 2009
    I have 2 X2's and they both have the same problem.  I will look at the post and see if I can fix them.  Thanks for the information!
This error is to do with the light tube - 4 retangular mirror's just after the colour wheel. The dark band is where the bonding for the mirror's is failing, the spring clip holding the assembely inplace pushes the top mirror down slightly causing the dark band as mentioned.
To fix this use a high temp glass glue and very careful clean, reposition the mirror's (in the correct position). Allow to cure fully then re-assemble the unit.
I have only have had to do this twice the 1st time using a sub standard adhesive and dark return a few weeks later. The 2nd I did some reseach and have a quailty glass glue. The X2 has been fine for many years now with no sign of the band re showing.
hope that has helped you.?
ps. if you are rubbish at doing stuff like this - just don't try, it's fiddly and requires a good understand of what you are trying to achieve. A perfect retangular tube with parrallel sides...!!!
Posted on Apr 08, 2008
    Problem Solver:
  • 5 Answers
This is due to misalignment of the light tunnel which is basically a four faced mirror glued together try to replace this or get if glued back again to its original form or better yet buy a light tunnel assembly
Posted on Feb 09, 2009
I had this problem on a Benq MP721 so there may be several DLP projectors that use the same mirrored tube method of channeling light to the lens. When fixing the 4 mirrors, I used high heat silicone. Just clean the old glue off the mirror with a razor blade first and apply a blob of silicone in it's place. Silicone sticks well to glass but you will have to make sure the mirrors stay in place while it sets. While you have it apart, check the glue on all of the mirrors. Chances are the glue has dried and cracked and will eventually give you trouble.
MJP
Posted on Dec 10, 2008
"Is this a DLP or LCD"
If you don't know if the well known X2 is DLP or not you shouldn't suggest a solution.
Unless the X2 was exposed to extremely dirty conditions or was used constantly & daily for years, I don't believe the DLP chip could be contaminated. Although the optics (mirrors, wheels, & lenses) are not 100% sealed from dirt they are sealed better than in their older models... which seemed to collect dirt like a vacuum cleaner. The DLP chip housing is sealed. So unless the seal somehow blew a leak, I doubt if it's contaminated. If the DLP chip developed a defect though, it's not repairable.
Infocus won't sell you replacement parts, service data, or any repair tips at all.
Infocus offers more bang for the buck than others, & the ones I use (4, including 2-X2s), which I use for shows on the road, take a little banging around, temp. extremes, & dirty environments, & still function well, they offer no support whatsoever... other than tell you to send the unit in & pay them more than what it's worth just to have them "look at it". They'll offer you to trade it in on a new model too. They'll knock off only a few bucks on a trade in. If you buy a new model from them, they charge you twice as much as you can get a new one from Amazon, NewEgg, or TigerDirect, so trading it in to them is not an economical option.
Did you clean all the optics or just the lenses? Dirt is most likely to collect on the color wheel or nearby mirror (not the DLP chip). Also the siver surfacing on the mirror may darken or peel away along an edge from extreme wear & heat.
Also the bulb itself may warp with age causing it's beam to no longer be centered, or it's reflector will have it's silver peel away, causing a bright or dark spot along an edge, in a corner, or anywhere in the frame. If you see silver peeling away from the reflector or dark spots on it or on the bulb, replace it, & save the old one as an emergency back-up bulb (a worn bulb is better than no bulb.
But beware, bulbs that show a lot of wear are the ones most likely to explode someday... throwing very hot shards of glass into the projector & possibly through the air vents, & venting toxic mercury vapor into the air. So worn bulbs should be used for back-up only, & not for regular use.
Posted on Nov 15, 2007
  • unclegadget Nov 15, 2007
    Oh. I forgot to mention with heat & age, the optical assembly may warp with age. This may cause a dark or blurred spot on a side or corner. Leave the lens mounting screws about 1/2 to 1 turn less than tight. With the projector operating see if you can shift the lens assembly a little back & forth to eliminate the problem. When you shift the lens, try to re-focus it too. Place a spacer washer between the assembly where it's separated when the image clears up, & tighten the screws.
    Genius:
  • 2,985 Answers
Is this a DLP or LCD type?
Posted on Sep 30, 2007
SOURCE:
Have Infocus X2 projector. When on a dark shadow line appears down the left side of screen. Could it be a bad lamp?
no it is not lamp problem. it must be light tunnel problem.
after lamp there is tunnel for light travel, made from 4 pieces of mirror.
this tunnel is glued. glue tend to break in time so the tunnel is no longer doing its purpose.
open this part of projector, there should be 2 little screws holding it. repair it by reposition mirrors and glue them from outside by little drop of temperature resistant and elastic glue. that's it !
Oct 03, 2010 | InFocus Projector Lamp for LP340, LP340B,...
Hello, My Infocus x2 projector works properly, except for the fact that it casts a dark strip by the side of the screen, like if it would be a burn stain. What should I do to fix this? Thanks in...
The light tunnel is collasped or it out ouf adjustment or the mirror inside the lens assy has been jarred out of adjustment. All of these need to be repaired by a technician.
Sep 22, 2010 | InFocus Office Equipment & Supplies
X2 OHP mounted on ceiling fixture. Image is dark on right side
Yes it will have to come off the ceiling. It sounds like the light tunnel has collasped. This is located under the colorwheel. If you can get a new tunnel , be careful removing the colorwheel so no segments break off of it...make sure the new tunnel is pushed against the "lip" before screwing the tunnel clip back into place.
Aug 02, 2010 | InFocus X2 Projector
We have an InFocus LP70+. we have had a dark strip along the right side of the projected image. That dark strip has spread across so that now we only have a strip of the image along the left side. Not sure...
the light tunnel (integrator rod) has collapsed and needs to be replaced. you could either buy the part from an infocus service center or send it in to one for repair. it is, however, a pretty involved repair. if you are mechanically inclined, then try it. otherwise, send it in. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 10, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
Infocus X2 projector, white vertical strip on right quadrant.
on the X2, the dmd chip is attached to the main board on the bottom of the machine. you need to take the top case off, as well as the 2 power supply boards. push the dmd chip (behind the lens assembly) back onto the board.
Jun 04, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
LP70+ image problems
the colorwheel is dirty and needs cleaning (or replacing), or the light tunnel is starting to collapse (and needs replacing).
Nov 06, 2008 | InFocus LP70+ Multimedia Projector
Blurring
This can be a fault with the lens or the imager. It is hard to know without doing some tests, and trying a new lens and a new imager.
Jerry G.
Apr 28, 2008 | InFocus X1 Multimedia Projector
Losing image
i have a very simliar problem, i found a way around it by changing a seeting in the advanced options. somehow, my horizontral position was changed from wahtever the default was to 88, which set it too far to the left. set it back to 50 and while the image was good, the menu is still in the oddly placed area....oh well....hopefully it's not the bulb, i just changed the damn thing less than a year ago
May 12, 2007 | InFocus ScreenPlay 4805 Multimedia...
4,974 people viewed this question
Top Compaq Office Equipment & Supplies Experts
Thomas F. Schneider
Damen Wong
Damen Wong
Alun Cox
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
