Question about Alpine CVA-1004 Car DVD Player
Aux input will not play sound when I hook into my smartphone
When I try to hook an audio aux cable from my head unit to my smart phone it will not play any sound?? ...I dont have my cd changer or dvd player hooked up to the head unit at this time,, is that the problem??
SOURCE: Alpine CVA-1004
lol i had the exact problem that you are having with my alpine. The solution is taking the blue cord that was inside the vehicle (forgot what cord it was) and actually connecting it with the other blue cord thats different makes the factory amp read the cd player and ta-da it works. crazy isn't it
Posted on Apr 04, 2007
SOURCE: cta-1505 auxiliairy input
you supposed tu turn mute off and the pink cable to ground
Posted on Mar 04, 2008
merle840
  • 113 Answers
SOURCE: Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Posted on Mar 27, 2008
SOURCE: aux input not working for mp3 player
Hi to you all. CAN YOU HELP ME? i have peugeot 206 and i have new kenwood CD MP3 and i also have aux input but I cant get any sound to come out at all?
Posted on Jul 12, 2008
burkholder
  • 25 Answers
SOURCE: alpine indash reciever 1004
there is a wire on the back of the unit marked hook up 2 parking brake....what i did was ran that wire to a toggle switch and to the cigarette lighter ground and mounted the toggle switch on my dash...then all u have 2 do is flip the swith off and on and it tricks the player to thinking the car is in park and will play right away...
Posted on Jul 27, 2008
How can I hook up an auxiliary wire to play my IPhone on the JVC KD-AR5000
After looking up your unit's info, I found that the aux input is on the rear of the unit. Pull the unit from the dash, being careful not to disconnect any wires (sometimes the antenna adapter wire is too short and must be disconnected to work behind the unit. Just don't forget to reconnect it before putting the unit back in place). Plug one end of a 3.5mm aux cable into the aux input on the rear of the unit and feed the other end thru the hole where the unit sits in the dash and out the side of the center of the dash to either the driver or passenger footwell. Replace the head unit and GENTLY pull the rest of the slack out of the aux cable but not so hard that you disconnect it from the head unit. You can tuck any excess aux cable up under the side of the console where the plastic meets the carpet, & if you wanted to get really fancy, you could drill a slot in the storage area of the console big enough to fit the cable, but small enough so the end doesn't fall through so you could plug your phone in and hide it all in the console out of sight. Then just switch the source on the unit to aux and enjoy!
Jan 12, 2014 | JVC Arsenal KD-AR5000 CD Player
I just bought the aux cable to connect my I phone 4 to my cde-9881 alpine stereo but when I hooked it up my iPhone connects to the head unit but only plays music thru the speaker on the phone. Why??
try playing your music first on your phone then with the cord alreay in your radio, plug it in to your phone....If that doesnt work, might be a setting on your radio....is it on aux in????
Mar 17, 2012 | Alpine Car Audio & Video
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Panasonic SCBTT350 Theater System
I would like to plug in the sound of my television set to the panasonic SC-PM08. I tryed to do that by plugging in the tulip plugs in the "aux" connections, but no sound comes out. what could be the...
You mention "tulip plugs"! are you referring to your RCA jacks in the back of your unit? That is what the 7 inputs are to the right of your speaker connections.
When you hook your "stereo TV" to your external sound unit
you need to run your cables to your aux input from your audio out jacks on the back of the TV. Once this is done you need to configure your TV and your sound unit to work with each other. You need to go into your TV settings and tell it where to send the audio to. If you hooked into the front audio output then you need to pick that selection. If you hooked into the back audio out you need to pick that selection. Once you have completed that you need to tell your sound unit where to pick the sound up at. If you plugged into the aux then put your sound unit on aux. If you have more than 1 aux pay attention to what aux your TV is coming in on and set your sound unit accordingly.
Mar 09, 2010 | Panasonic SC-PM08 Shelf System
I cant figure out how to get my playstations 3's audio to play through my koss surround sound
Hook your video source up to the display (TV), and run your audio cables to an input on your surround sound receiver. Note which input the audio cables are hooked up to and set the surround sound receiver to that channel on the front of the receiver. For example, if you hook up the audio inputs to "AUX" in, then make sure you select "AUX" on the front of the receiver. If you hook up the audio input to "DVD" on rear of receiver, make sure you select "DVD" on the front of the receiver. The connections on the rear of the receiver have to match the selection on the front of the receiver. Make sure that the cables are hooked up to "INPUT" on the surround sound receiver. It doesn't matter how the inputs are labeled (DVD, AUX, etc.) they all do the same thing. Check volume and mute controls on receiver as well. I know it sounds trivial, but sometimes it's the little things that get overlooked and cause problems. I hope this helps and good luck.
Oct 28, 2009 | Audio Players & Recorders
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
The aux input will not work
you must go back into the menu and turn on aux otherwise the head unit will not recognise the aux devise that you are trying to plug in
Mar 25, 2008 | Kenwood KDC-MP3035 CD Player
Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Dec 12, 2007 | Audio Players & Recorders
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Lights up but will not play music
Check the RCA cables input,example your RCA input is AUX and the input selection in the control pannel must be selected AUX.
Feb 25, 2007 | Kenwood KDC-516S CD Player
Alpine CVA-1004 Car DVD Player Logo
20 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
