Question about Google Nexus 7
My son's Nexus 7 will not power on at all...I just tried holding the power button down for 20-30 seconds, but still nothing....
In addition to holding the power button down, try holding both the power button and volume down button for 23-30 seconds and see if then the device comes up.
Hope that helps!
Posted on Nov 05, 2013
WHY WON'T MY NEXUS 7 POWER UP? hOLDING DOWN THE POWER BUTTON FOR ONE MIN WAS NO HELP.
If the above fails, then pop the black plastic cover off using a credit card corner - it actually comes off quite easily. With the power connector at the bottom, you will see the battery - a big black rectangle dominating the left side of the device. At the top right of the battery is a connector with six wires attaching it to the main board. Gently disconnect the battery (use a fingernail or small flat screwdriver to push the connector out). Wait 30 seconds and reconnect. Put the case back on, plug in your charger and your Nexus will now turn on.
Sep 10, 2014 | ASUS Google Nexus 7 Tablet
Nexus 7 won't turn on
Pop the back off, unplug the battery for about 30 seconds, plug the battery back in, put the back cover back on. You will find it will start no problem.
May 19, 2014 | Google Nexus 7
How do i reset my nexus tablet ?
Hold the power button down continuously until it powers off. You may need to keep it pressed for up to 15 seconds. Wait 30 seconds for any residual electric charge to dissipate and then power on again.
May 06, 2014 | ASUS Google Nexus 7 Tablet
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 tablet wont leave the startup screen. I tried a hard reboot but it stays on that screen and wont turn off
(enter BootLoader)
Step 6: Toggle with vol down CLEAR CACHE & reboot
Nov 03, 2013 | Google Nexus 7
Does not turn
swipe down from right side of screen, disable the screen rotate lock
Oct 17, 2013 | Google Nexus 7
Nexus 7 wont turn on
You can try to do a hard reset by holding down the power button and the volume down button for 20-30 seconds. IF the device still will not turn on make sure it has enough battery or is plugged in.
If you still have problems you can try the following to do a factory reset:
  1. If your tablet is on, power it off.
  2. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power). You will see the word Start with an arrow drawn around it.
  3. Press Volume Down twice to designate Recovery mode.
  4. Press Power to restart into Recovery mode. You will see an image of an Android robot with a red exclamation mark.
  5. While holding down Power, press Volume Up.
  6. Use the volume keys to scroll to "wipe data/factory reset" and press Power to select it.
  7. Scroll down to "Yes - erase all user data" and press Power to select it.
Source: https://support.google.com/nexus/answer/2668187?hl=en
Hope that helps!
Sep 02, 2013 | Google Nexus 7
My nexus 7 will not turn on
You can try a hard reset. Hold down the power button and the volume buttons at the same time. The device should then power on and you can follow the on-screen prompts.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 will not turn on and its only a week old
You may want to try and do a hard reset/reboot which will hopefully bring the Nexus 7 back to life.
  1. Press the power button and both volume keys for several seconds. The computer screen will eventually blink off. Continue to hold until you see the Android recovery logo and the large Start selection at the top of the screen.
  2. Move the volume keys up and down to see the menu selections. If you don't want to factory reset, you can try to Power down or to Restart bootloader from these selections. The power key will select the option.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 Tablet
Google Nexus 7 Logo
56 people viewed this question
Top Google Tablets & eReaders Experts
noel
noel
David Payne
David Payne
Are you a Google Tablet and eReader Expert? Answer questions, earn points and help others
