Question about Briggs & Stratton Garden
Briggs and Stratton 6.25 wont start, pull cord pulls back when starting. Almost started but backfired through carb
    Sergeant:
  • 247 Answers
Replaceing the spark plug will usually fix it. If not, it may need new points.
Posted on Oct 18, 2013
  • CDUBYA
    CDUBYA Oct 18, 2013
    what kind of graphite? I have built many ATVs but this is my first lawn mower engine. Where would I find it?
woobie dog
  • 1273 Answers
SOURCE: My Briggs stratton mtd lawn nower does't wanna
The recoil line isn't disengagimg when the engine first comes to life, and it's pulling back in under power, choking itself off. Here's what to do:
Remove the sheetmetal cowl that has the recoil starter in it. Remove the wire screen over the top of the magneto and ratcheting mechanism. The ratcheting mechanism is the four cornered part that the cowl fit onto, and it is screwed onto the crankshaft end where it comes up through the magneto. Use a block of wood and a hammer to unscrew the ratchet. Careful here; the ratchet has steel balls in it, and you don't want to lose them. Clean out the ratcheting mechanism and put a liberal dose of graphite in the cavity. If the steel balls are out of place, put them back evenly spaced, and work the ratcheting mechanism to distribute the graphite. Reassemble the mower.
Best regards, --W/D--
Posted on Aug 21, 2009
  • 496 Answers
SOURCE: we have a briggs and stratton sovereign petrol
If I'm understanding you correctly, the pull chord is out and will not retract so you can pull again?
If this is so, I'm thinking that there may be some obstruction keeping your spring from returning the rope. The spring is wound like a clock spring. When you pull the rope, the spring wants to bring it back. Sometimes a twig or dirt or other type of abnormality might prevent the spring from retracting your pull rope.
You might need to loosen the engine cover to remove the obstruction.
Posted on Aug 25, 2009
  • 143 Answers
SOURCE: briggs and stratton quatum 5 hp lawn mower engine will not start
Sounds like your ignition timing. If the blade hit something solid while cutting it might have bent the shaft or sheared flywheel shear key. This is not hard to replace, just remove the engine cover and flywheel. If its not that, it could be inside the engine and that would be a bigger job Stephen.
Posted on Sep 20, 2009
Testimonial: "good info! thanks"
mowerman1857
  • 389 Answers
SOURCE: 13.5hp Briggs And Stratton snowblower.I tried to
Concerning your starter/pull cord problem, what has probably happened is that due to sitting idle for an extended period, the pinion gear had stuck in the down position on the clutch drive.
When you engaged it with power it spun as it was supposed to do but did not immediately spin up into the ring gear.
After you released the starter button and it began to slow down the gear spun up into the flywheel and jammed because it didn't have enough power to turn the engine.
A usually simple fix for this is to turn the engine backward by hand just enough to relieve the tension and the return spring will push the gear back down.
At this point, you can try the electric starter again and it should work properly. If it does not work, you will have to remove the starter and clean and inspect the starter drive on the top of the starter.
Concerning the fact that it would not start, you more than likely have some old fuel trapped in the bottom of the float bowl.
You may be able to remedy this by spraying some carburetor cleaner in the carb while trying to start it.
If it has spark and everything else is in good condition, it will start and run as long as it has carb cleaner getting to the engine so you may need to spray it a few times while it is running on that and sometimes the stale fuel problem will clear itself.
If it doesn't clear up and run on its own without the carb cleaner after 3 or 4 shots of spray you will need to remove the float bowl and clean it and the main jet with the carb cleaner.
Protect your eyes and bare skin while using the carburetor cleaner, it will injure you. Do not spray it on any rubber gaskets or seals, it will swell and ruin them.
Sorry for the "book" I wrote but I am trying to explore as many possibilities as I can to get you up and snow blowing!
Posted on Nov 05, 2009
Testimonial: "Cured the problem just like you said. Thanks"
  • 110 Answers
SOURCE: the timing on my 3hp briggs and stratton mower is
Timing is fixed - or at least it's supposed to be! There is a possibility that the flywheel key has sheared, allowing the timing to drift, but not likely.
No-start on Briggs engines are usually carb related. Test for spark, and if good, overhaul the carburettor.
Posted on Mar 16, 2010
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs and stratton 13.5 hp power engine that wont start. The engine is almost new, oil level is good and when I remove the spark plug cap and dold it near the top of the plug and pull start it I...
there may be safety switches, but if you are getting a spark, that is not the problem. After you cranked with no start, is the spark plug wet with gas? can you smell gas in the cylinder after pulling the plug? It could be that your carb float/needle valve are stuck closed. Try lightly tapping the side or the carb.
Jun 08, 2017 | Briggs & Stratton Briggs Stratton Intek V...
I have just purchase a Sears 22 Lawm mower, with a Briggs and Stratton 158cc engine. I prime the motor it act like it wants to start but then dies. I pull it and try to strat it several more times and it...
The procedure for starting an engine is as follows:
  • Check that you have the throttle in the start position and/or on high revs with choke on
  • Prime the engine by pushing the button about 5 times
  • Pull out the cord until you meet resistance. Then let the cord go fully back into the engine and then pull the cord out sharply. Repeat this until the engine starts but not more than a few times.
  • If the engine doesn't start, try pressing the primer button another few times then try to pull start the engine
  • If the engine doesn't start after a few pulls it may have flooded so leave it for a few minutes before pulling the starter rope
Apr 30, 2011 | Briggs & Stratton Briggs Stratton Intek V...
The pull cord is locking up and wont allow it to turn over
you need to remove the front cover where the pull start Cord is and check for anything that is blocking the Cord a broken spring under the Cord wheel can cause this as well
Sep 23, 2010 | Briggs & Stratton Briggs Stratton 6200...
26 hp briggs it is firing and full of fresh gas but wont start.
Well you didn't indicate what its mounted on but the basics are: spark and fuel. Pull a spark plug and make sure you get spark. If you do then it must be fuel. You can try a shot of starting fluid (small amont) into the carb, if it runs on that you know you have a fuel problem. Be sure the carb is getting fuel from the tank. Clean the carb. Maybe a carb kit. With today's fuel, you must take care of your fuel system. Use Sta-bil year round. Fuel can go bad in 60 days.
Jul 18, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
Jun 22, 2010 | Briggs & Stratton Briggs Stratton...
Briggs and Stratton outboard. I have a 5 hp briggs outboard that we have cleaned out pretty good. The carb has been cleaned also. The engine will start and idle perfectly but when you start to throttle it...
If you have started the engine out of water, you may have locked up the lower end, the prop gear.  If you think it is the carb or a fuel problem, try and get your hand over the carb when you rev it up. if you put your hand over the carb right as you rev it, then pull it off, she will pull more fuel in and should go on to rev up. if this works you still have a port cloged in the carb.
Aug 11, 2009 | Boating
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
183 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
