Question about Garden
John deere 1508
Blade shaft on bat wing fell off how do I fix this?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
The spindle fell out of the housing?
Posted on Nov 21, 2013
  • 473 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
  • 67 Answers
SOURCE: john deere, how to speed up motor so blade speed
you dont unless you have a tac to check the rpms they should be at 3500 no more unless you want to buy a new motor
Posted on Sep 01, 2009
brado83
  • 106 Answers
SOURCE: need diagram for installing mower belt for blades
Hey if its a 42" cutter deck this should be the one:
http://i876.photobucket.com/albums/ab330/Brado83/JDDeck.jpg
It may be a 48" in that case it would be different
Brad:)
Posted on Sep 16, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
nova2nv
  • 197 Answers
SOURCE: how do we service the blade / brake clutch
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Posted on Nov 15, 2009
How to replace a blade shaft on d105 JD
Did the blade come off?? I believe it's time for a trip to the "John Deere man".. Stop "trying" this.. you could cause more damage to other parts..$$$$...
Jul 19, 2017 | Garden
Mower blades move but no gears forward or back, very suddenly quit.
Rex, check the drive belt,old stretched, loose, broke, fell out of position Tension er weak or seized if equipped, worn out pulleys.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tightening the belt on John Deere L110 Tractor
https://jdagccc.custhelp.com/app/answers/detail/a_id/428/~/mower-belt-comes-off---100-series
How to Adjust John Deere Drive Belt
John Deere Fail LA145
Apr 23, 2016 | John Deere L100 Series
How to change cutting blades on john deere Z710A mower?
you should be able to life the deck to its highest possible setting, and get a wrench to remove the blades, you'll need 27" blades. the shaft may have a star pattern as well as the blades. when you replace them, you want to make sure you remember what direction the blades were sitting when you removed them and put them back in the same way, so you dont have blade interference
Jul 17, 2014 | John Deere Garden
Why isn't the center blade on a john deere LX178
Of course with everything off, reach under the deck and turn the center blade by hand. If:
1. the blade turns by itself and nothing else moves, you need to tighten the retaining bolt more.
2. the blade, retaining bolt and drive shaft turn, check to see if the pulley above it is turning.
a. If the pulley turns freely check that the drive belt is going around it to power the blade.
b. If the blade turns with the drive shaft and the pulley doesn't, check that the pulley is still properly connected to the blade shaft. Some have a key in them that can split, others just have a bolt on top holding them tightly on the shaft.
Jun 16, 2011 | John Deere Garden
F935 re-aliwning drive shaft for deck after blade change?
If you look close at the splines of the shaft you would see 2 of the splines are pinched together at the end of shaft and on the recieving end of shaft you would see that there is a small cutout where the 2 "pinched" splines would line up when slid together.
May 16, 2010 | John Deere Tractor 1020, 1520, 1530,...
I have a John Deere model# LA105 , and it is cutting uneven because one blade sets lower then the other,the blades are not bent.
I have a John Deere lawntractor, 105. Won't start. Gas getting to the carb, but not getting into carb. Is this a common problem. Has been setting for a year. Any suggestions on problem
Sep 11, 2009 | John Deere Garden
Lost the bolt/nut to my riding lawn mower!
That is a cap screw you are talking about. The size of it is 7/16" X 1-3/4". The John Deere part # is 19H2563, but I am sure you can just get one at the local hardware store. I could not find out for sure, but on most blades they use a fine-thread bolt/screw. If you can tell the difference, check before you buy, or just buy both and see which one threads in easily. Hope all this helps.
Mar 31, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
