Question about Toshiba Computers & Internet
Toshiba Satellite A200-AH3 will not accept more than 2GB of RAM
    Scholar:
  • 141 Answers
The max RAM you can install onto it is 2GB. If you are thinking overclocking it (using RAM above 667.0 MHz), then it's a bad idea the cooling system was designed to cool it at stock speeds, not at overclocked speeds.
If you still want to try and burn it, then make sure you have matching sticks of RAM, then enter the memory configuration menu in the BIOS and disable the default memory profile. Adjust your memory multiplier by selecting a preset overclock option or by typing in the RAM clock speed. Use increments, one or two at a time, that match consumer-grade products (DDR3 RAM is typically sold in increments of 800-1066-1333-1600-1867-2133); save the changes; and exit the BIOS.
Good luck
Posted on Oct 18, 2013
    Sergeant:
  • 247 Answers
Possibly a bad motherboard.
3 Suggested Answers
  • 73 Answers
SOURCE: I'm formatting my laptap to windows xp, i need a support software
get the installer disk from windows that is the only legal way to do it (hint)
Posted on Mar 24, 2009
  • 10406 Answers
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
Posted on May 27, 2009
Satellite A200-AH3 will not accept more than 2 GB of RAM
Hi Sir, you may encounter that because your motherboard doesn't support larger memory. If you want to upgrade your PC, replace your motherboard.
Hope it will clear your mind.
Thank you.
Oct 17, 2013 | Computers & Internet
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
I have Toshiba satellite a200 laptop when i turn on my laptop it has continues beep sound and it doesn't log in
check or change your ram first then also make sure that your keyboard is not having a stuck button.
regards
Apr 02, 2011 | Toshiba Sattelite® Pro A200 PC Desktop
Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
Jun 15, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba laptop wont start up
change the ram (Random Access Memory) on your laptop your ram is not working
Regards
manish
Mar 24, 2010 | Toshiba Satellite A200-0ET00X Notebook
Mar 24, 2009 | Toshiba Satellite A200-S18X01G Notebook
Why Won't My Toshiba Satellite Laptop (A200 -AH3) Not Burn Discs?
Look for any software on the machine that uses the the burner. Start by updating it (many of these programs use what are called burning engines to process the request to write to a cd, and if theyre damaged, then the writing process will appear to occur, but wont do anything). If you use programs that download and manage music (such as Limewire, Bearshare, or Napster), uninstall them.
As a last ditch effort, you can try the istructions in this Microsoft article:
http://support.microsoft.com/kb/314060
Be warned, you will have to reinstall the software needed to burn your CDs if you do this. It has fixed 99% of CD burning issues out there. Good luck
Mar 05, 2009 | Toshiba Satellite A135-S2386 Notebook
EXTENDING EXIST 2Gb RAM to 4Gb
hai ,frist u go to
start--my computer(right click it)---manage---disk management---
see your new hard disk & right click and shirnk volume
Jul 13, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
