Satellite A200-AH3 will not accept more than 2 GB of RAM
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 141 Answers
Hi Sir, you may encounter that because your motherboard doesn't support larger memory. If you want to upgrade your PC, replace your motherboard.
Hope it will clear your mind.
Thank you.
Posted on Oct 18, 2013
  • 12 Answers
SOURCE: I installed 2 gb Of ram to my toshiba satellite a135-s4656 and
Check to make sure the screensaver settings are correct. Adding RAM to a PC won't change how the screensaver works, unless you also added some software that is not letting it sit idle long enough for the screensaver to come on.
Posted on Mar 18, 2009
  • 73 Answers
SOURCE: I'm formatting my laptap to windows xp, i need a support software
get the installer disk from windows that is the only legal way to do it (hint)
Posted on Mar 24, 2009
md_ehsan_1
  • 255 Answers
SOURCE: i wanna upgrade RAM ofToshiba Satellite A200 ,
upto 2GB you can upgrade it, ddr2 ram
Posted on Jun 30, 2009
  • 39 Answers
SOURCE: put two gegs of ram in my toshiba satellite a55-s1063
1. The ram you put into your computer man not be compatible with the computer itself. You can find out what kind of memory your computer takes by doing a google search or asking a technician at your local computer store.
2. You may have put too much ram in. www.pcmemorystore.com sells as its largest ram chip for your computer a 512meg stick. This likely means that the most memory your laptop can take is 2x512meg, or 1 gig.
3. The memory may not be correctly seated. Installing memory isn't rocket science, but you have to make sure you have the chips seated properly before trying to boot your machine.
Posted on Aug 14, 2009
  • 46 Answers
SOURCE: Satellite A205-S4617 15.4" Notebook PC (Intel Core 2 Duo Processor T5500, 2 GB RAM, 250 GB H... PC Notebook: laptop is not starting...what should i do?...
First check wheather battery is dead . Charge it completely and also check the lights while charging.
If you think its battery issue try the following remove the battery and then press the power on button, it help release and electricity left then place the batter back . and Power it on.
If the lights just blink then...press and hold the battery button for force a shut down then power it back on.
=======================MENTOR======================
Posted on Jun 01, 2010
I have a Toshiba Satellite A200 24A. The videos that I run from YouTube and other such sites do not run smoothly. They are jerky/choppy. What could be the reason. Please do not tell give me complicate
Anytime your streaming videos are playing but not running smoothly, you either have a slow internet connection and aren't downloading fast enough to keep the data streaming OR you don't have enough RAM to keep up with the streaming data and everything else that's going on in the background. Check your internet connection speed first. If you have a good download speed then add RAM to your pc. (You could also try clearing cache on your browser)
Jun 13, 2012 | Toshiba Computers & Internet
How can I increase memory of toshiba Satellite A105
A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
Sep 02, 2010 | Toshiba Satellite A105 Notebook
Toshiba laptop wont start up
change the ram (Random Access Memory) on your laptop your ram is not working
Regards
manish
Mar 24, 2010 | Toshiba Satellite A200-0ET00X Notebook
Toshiba Satellite A215-S7407 ram upgrade
Try to disconnect the new ram you just bought one at the time to see which one is defective. Also, 32 bit operating systems won't detect 4 Gb or ram, but they will show 3 Gb (even though they will use all 4 Gb). To resolve this issue, make sure that if you are using windows Vista to download the latest service pack 1.
Apr 03, 2009 | Toshiba Satellite A215-S7407 Notebook
Mar 24, 2009 | Toshiba Satellite A200-S18X01G Notebook
Why Won't My Toshiba Satellite Laptop (A200 -AH3) Not Burn Discs?
Look for any software on the machine that uses the the burner. Start by updating it (many of these programs use what are called burning engines to process the request to write to a cd, and if theyre damaged, then the writing process will appear to occur, but wont do anything). If you use programs that download and manage music (such as Limewire, Bearshare, or Napster), uninstall them.
As a last ditch effort, you can try the istructions in this Microsoft article:
http://support.microsoft.com/kb/314060
Be warned, you will have to reinstall the software needed to burn your CDs if you do this. It has fixed 99% of CD burning issues out there. Good luck
Mar 05, 2009 | Toshiba Satellite A135-S2386 Notebook
How much Ram can it takeTOSHIBA Satellite A200 AH 3
Your laptop supports 4 GB.
4 Gigs of RAM is the maximum allowed on this particular model.
Read specs here.
Dec 01, 2008 | Belkin F1DK102P 2-port KVM Switch
Toshiba flash cards " not Responding"
Dear Sear
First of all i aprechiat your willing to offer me a solution for the problem (flash cards are not responding).My laptop has thise model; Toshiba Satellite A200 - 1 GB - intel(R)Core(TM)2 CPU T5300 @ 1,7 MHz.
I solved the problem just with shuting down the mashin, that's all.
I thank you indeed for you respond and i'm looking forwards.
Best regards
Yours
Aweti.J
Aug 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
