Question about Dogs
Anchor screw in cement porch - Dogs
2 Suggested Answers
  • 2458 Answers
SOURCE: cement around heater elements has cracked and fallen out
is it working ?
Posted on Jan 16, 2009
How do you fix a Moen Towel Bar when the mounting system has come apart from the wall?
There are larger screw-type anchors available at a hardware store. If the hole is a half inch, you can possibly use an expanding wing type "molly" anchor. it's hard to assemble the screws through the bracket, then put on the butterfly, and shove the folded butterfly into the hole, but it's doable.
Jul 28, 2014 | Moen YB2218BN: Brantford 18 in. Towel Bar...
The wires have come out of the switch
take it to an electronic repair shop in town karen don't fix yourself!
Mar 22, 2014 | Bell Labs Protecta Load-N-Lock Anchoring...
No instructions giving to erect our tent 6 man regatta hyperdome model no 927/5887
I bought one of these yeaterday. The instructions - for what they are worth are sewn inside the carry bag. So I decided to put it up today. Not as easy as i would have thought, but then this is my first tent of this size. ( saw a nice Outwell Montana 4 in Millets for 225.00 which would have been my tent of choice). But at half price in Argos I couldn't argue that one.
So to put it up.....
lay out the fly sheet in the approximate final position. put poles in as per instructions ..blue to back red to middle and blue to front.. across the tent. ( the pole guides are all colour coded.) Make sure poles are in pins at the base of fly sheet (bending gently to attach). these are attached by the black elastic straps.put in porch pole, put in front to back poles left and right.
Anchor back of tent temporarily with pegs. Lift from porch forward to lift tent. Temporarily peg base of poles, straighten out so that the straps inside tent are approximately perpendicular to each other. Move poles to tension flysheet and tighten anchor points on flysheet using straps buckles to pull flysheet down as far as possible ( to help prevent draughts)., anchor guy lines when happy with final position.
Put up inside ground sheet and attach to points on inside of flysheet. put up rooms starting with the rear yellow hook and work around to front red hook.
These instructions were not specifically provided but this was our first try and probably could be improved on. It requires 2 people for speed if nothing else.
Enjoy
Jul 31, 2011 | Sport & Outdoor - Others
I installed a Moen Sage toilet paper holder. The right cover that attaches to the wall hardware via a small screw is loose and no amount of tightening corrects the problem. What am I doing wrong?
It is likely that the the mounting post on the wall has pulled loose.
You will need to remove the paper holder and inspect themounting posts; loosen the set screws in the base of the posts to do this.
Try tightening the screws holding the mounting posts to the wall. If the screws are unable to hold tight you will need to replace the wall anchors if they have been used.
Remove the mounting posts and the wall anchors and replace with new wall anchor, preferably a toggle anchor designed for sheetrock if possible.
With the wall anchors in place attach the mounting posts and install the paper holder; tightening the set screws in at the base of the posts.
Installation instructions for your product can be found here:
http://www.moen.ca/shared/pdf/yb2208sp.pdf
Oct 18, 2010 | Moen Home
Is there an easy way to mount a pedastal mailbox on my lawn. do they make screw anchors for tying up dogs but with a nut on top thanks!
ive never seen suuch a screw anchor but you could dig a hole and set some regular anchors in cement that line up to the post hole from the mailbox post , i have found over many years of experience that using concrete for mailbox posts works the best, you can actually dig the hole set the snchor screws and then even put a little dirt over the setting concrete than put the post on the anchor screws while the concrete is setting up so that they will be aligned properly but do not tighten them until it has set up over night
Sep 15, 2009 | Salsbury Industries 4365blk Bolt Mounted...
Leaking basement foundation
It sounds like the ground has settled around the area where the leak is, hence the traveling water. The right way to fix the problem would be to remove the porch, dig up around the basement wall, apply a sealant to the outside of the wall, install weeping tile and re-grade the soil to drain away from the house. Your best bet to begin with may be to try to re-grade the soil so it is sloping away from the house, however this is only a temporary patch, if temperatures get below freezing there is a possibility that moisture in any crack in the wall could cause further cracking and leaks.
May 25, 2009 | Hand Tools
I have a John Deere Ride on Toy stuck in reverse
Are the actual shifter levers not engaging or are the switches not clicking?
These Peg Perego Parts are available at http://www.shopjandl.com/, but I would check to make sure if it is the switches specifically or the levers under the shifter.
It is simple to check the shifter by taking the 2 screws out that hold the shifter in.
Hope this helps.
Let me know what you find.
Apr 16, 2009 | Peg Perego John Deere Turf Tractor
Installation
If you are going into drywall then a threaded drywall anchor like this
Will be best.
Yopu can buy them at any hardware store. They screw right into the drywall and then another typical screw goes through the mounting plate into this anchor.
I recoment getting metal anchors as the plastic ones break easily.
These hold MUCH better than the push in plastic anchors.
Dec 30, 2008 | American Standard 6723S 'The Standard...
Dogs Logo
292 people viewed this question
Top Dogs Experts
Gary Clark
Gary Clark
Level 1 Expert
Ruth summersides
Are you a Dog Expert? Answer questions, earn points and help others
