Question about Vizio XVT472SV 47 in. HD-Ready LCD TV
Vizio XVT472SV: Had a member previously helping me diagnose the problem whether it was the Power Supply or Mainboard. Pretty certain now that problem is in the Mainboard. But here's my problem. i got this unit -dead- as is, so don't know if there are other problems in it. i hate to shell out $100 bucks for a mainboard only to find other problems. i have several years in electronics and have test equipment. If I could locate a schematic for it, i could trace it down to the component and repair it myself instead of swapping it out with an expensive board. Any suggestions? Thanks!
4 Suggested Answers
dharknesst
SOURCE: Vizio VO370M will not power on. Vizio log stays
did you ever finish the repair?
Posted on Dec 07, 2011
SD Tech
  • 14553 Answers
SOURCE: vizio sv320xvt mainboard not sending +5 to t-con
The missing +5 seems to me to be a real clue--try to follow it back to mainboard etc---it can be a open or just a processor is not switching it on---impossible to really get a component schematic with voltages etc as they do not want to sell and do not sell discrete parts--if you find it is there Google the internet for that board--seen some on ebay from dropped or junked sets and others elsewhere.
I do not like "replace the board either" but in some cases (which is what the maker wants it is the way the repair work is done now.
over 30 years here in experience from tube type sets to current junk.
Posted on Nov 06, 2012
protvrepair
  • 153 Answers
SOURCE: Relay clicks when applying power. Yellow light
Amber light on means standby voltage is high. IF amber light does not go white when power button is pushed the its one of two things.
A. No power on command from main board. Usually labeled PS-On. Should go high from 3.3v or maybe 5volts. If not present Main is defective.
B. If the ps-on line is going high then your problem is a defective power supply.
Posted on Oct 15, 2013
I have a Vizio model# E241-A1-A1 with no power.Replaced the power supply board, still no power. Can you help.
Hi Clifford,
Why did you replace the power board? No power in your tv may result due to some other reasons also. Diagnosing a fault in any TV needs a certain amount of knowledge and expertise. Without that you may succeed at times, not always. By the way, do you get red led on plug in?
May 05, 2015 | Vizio Televison & Video
I need a manual for vizio tv model xvt472n
http://www.retrevo.com/support/Vizio-XVT472SV-TVs-manual/id/23616ci265/t/2/
Close as I could find for your manual. It sghould give you the answers as it is very close to yours. Also - please note Visio does hacve some of the best customer support I have ever used. They have always been extremely helpful to me. BUT - remember to be polite! As the old saying goes you get more flies with honey than vinegar. I am almost certain those who are rude do not get the superior help there tech support line will give if you are kind!
Dec 19, 2014 | Vizio 42 in. LCD TV
Where can I find a mainboard?
I found this link with the motherboard in stock:
Jan 20, 2014 | Vizio XVT472SV 47 in. HD-Ready LCD TV
Relay clicks when applying power. Yellow light comes on. TV is dead otherwise. Power supply is outputting +5, 12, and 24 volts Mainboard (3647-0282-0150) has +5 and 12 volts always applied. Checked...
Oct 15, 2013 | Vizio XVT472SV 47 in. HD-Ready LCD TV
Vizio sv421xvt issues
It sounds like a main board issue but could be a power supply issue. I will tell you from my experience with Vizio TV's, main boards are more likely to fail than power supplies. But to be sure, you will want to either get a diagnoses or if you're handy do a little troubleshooting. The power supply and the main board are not cheap so you will certainly want to be sure before spending any money.
Nov 24, 2012 | Vizio SV421XVT 42 Class LCD HDTV - 1080p,...
Vizio XVT472SV will not power on. The orange standby light lights up. Nothing else.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_3_2012_10_18_35_pm.jpg
May 03, 2012 | Vizio XVT472SV 47 in. HD-Ready LCD TV
I have a vizio vp3222 in plasma tv. My husband would like to repair it but he/we don't see anything wrong when we open it. It turns on and then immediately off. We need a diagram as to what is what and...
Most likely, it has a failing power supply.
My experience is that the Vizio support people can provide the correct part number for a replacement power supply, and the parts they sell have been very reasonably priced in comparison to other online sources.
Once you call them and they help diagnose the problem, you can order the part. With that part in hand, identifying it in the TV is easy, and it's just a matter of installing it.
Pretty easy job, actually.
Jan 08, 2010 | Vizio VP322 32 in. Plasma TV
TV will not turn on - yellow power light is on.
If the led light is on you only need to replace the mainboard.
and yes you can do it yourself, its pretty easy just order a new mainboard, open the TV and replace the mainboard, it is as easy as it sounds.
Jun 06, 2009 | Vizio L32 32 in. LCD HDTV
Vizio XVT472SV 47 in. HD-Ready LCD TV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
