Question about Kitchen Ranges
Frigidaire fgf366csc gas kitchen range
Sometimes the oven makes a noise and then the oven and the display shuts off. Bad circuit board?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
You will need to replace the control board (clock) on the unit. Pull the unit away from the wall, unplug it and remove the rear cover on the console to gain access to it. Be sure to take note of where the plugs go! Here is the part to order. It comes with a 365 day, any part, any reason return policy.
Posted on Oct 17, 2013
  • Rick
    Rick Oct 17, 2013
    Thanks
  • 833 Answers
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Posted on Dec 13, 2007
BNewberry
  • 93 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
SOURCE: Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Posted on Aug 02, 2008
  • 9 Answers
SOURCE: Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Posted on Apr 11, 2009
  • 341 Answers
SOURCE: frigidaire gas range ES100 oven will not light
I had a similar problem with my Kenmore and it was the Igniter. Cost me about $85.00 for a new one. Sometime on the back of the range there is a little pocket where sometimes a schematic is there and ( I don't know about your Frigidaire) but with my Kenmore it gave troubleshooting info that was very helpful in determining the problem.
Posted on Jul 18, 2009
Our stove made a wierd noise and shut down. We replaced the oven clock circuit board but it still doesn't work.. What else should we look for
Hello Marsha Abbey, thanks for your post!
From what you have described your Frigidaire range made a weird noise and shut down. I understand that you have replaced the oven clock and the oven is still not working properly. It is possible that your terminal block or wiring harness has shorted. I would recommend contacting a professional technician to come out and perform a diagnosis and repair on your range. This will help to avoid any unnecessary part purchases. Best of luck! -Matt
Feb 25, 2015 | Frigidaire Kitchen Ranges
What's wrong with it?
Good Morning Friend,
I see that the display panel is no longer working on your Frigidaire range, model# FEF355. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Sometimes the control boards inside your appliance can miscommunicate with each other and can cause things such as this to occur. Most times they need the hard reset to get them communicating again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
Frigidaire fgf337awj gas oven does not light
Hi - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Sep 17, 2012 | Frigidaire FGF337BC Gas Kitchen Range
Frigidaire duel fuel range model # 52 393H3 3S CPDS389CC1 Ser NF24920776 the range tripped the breaker while baking,after resetting the clock flashes and PF is displayed and no buttons on panel work.The...
I have the same problem with an identical oven. In fact my serial number indicated my oven rolled of the production line six ovens before yours.
Please let me know how you fixed the problem.
Thank you.
Kaid
Mar 16, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Frigitaire gas range, elect. oven ..."or"..displayed and control
Check all circuits in the range for a short to ground and correct the short..
Your electronic controlis fried.
Power surges are electronic controls worst enemy.
Replace your electrinic control.
Feb 11, 2009 | Frigidaire FEF336BC Electric Kitchen Range
No Power to FGF366ESB Range
althougy ou cked circuit breaker did you try unplugging unit waiting 2 min then plugging back in. sometimes you get lucky and will reset. has to do with high voltage bleeding through to low voltage wiring. if it works, your good!!!! if not remove the back panel and check the clock/control for icoming power. as long as you have 110v going in at the black (L1) you should have a display. if you have powerand no display you need a new control.
Mar 13, 2008 | Frigidaire FGF366E Gas Kitchen Range
Fridgidaire elctric oven with the touch control pad
MOST OVENS TODAY HAVE THE CLOCK/CONTROL AS ONE UNIT THAT HAS THE RELAYS THAT TURN ON THE BAKE/BROIL CIRCUITS. SOMETIMES THE RELAYS FUSE THE INTERNAL CONTACTS KEEPING THE CIRCUIT RUNNING AFTER THE MICROCOMPUTER SHUTS DOWN THE CIRCUIT.
THE OVEN CONTROL WOULD NEED TO BE REPLACED.
IT IS ALSO KNOWN AS THE CLOCK.
OCCASIONALLY, THE MANUFACTURER WILL HAVE A SEPARATE RELAY BOARD AND CONTROL BOARD. FIND OUT WHICH CONFIGURATION YOUR RANGE IS AND REPLACE THE PART THAT CONTAINS THE RELAYS.
Dec 20, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Nov 10, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
112 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
