Question about Samsung DW7933LRAWW 24" Tall Tub Built-In Dishwasher With Tact-Button
Dw7933 wont drain - Samsung DW7933LRAWW 24" Tall Tub Built-In Dishwasher With Tact-Button
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Clear blockage from pump/pipe/s-bend spigot
Posted on Oct 18, 2013
My samsung dw7933 will no drain out all of the water and it makes a grinding noise. where can i find the error code?
It might not throw an error code. There is usually a filter and a drain. I have seen coins and hair pins etc get stuck in the pump and cause excessive wear. If you take the cover off the filter, get ready for some water to come out.
Oct 10, 2017 | Samsung Washing Machines
What causes a Low-level water error on the dishwasher. Samsung, DW7933 Series
perhaps if we knew the MAKE .information could be found
Jul 19, 2016 | Dishwashers
How do u fix a low water level error on a Samsung dw7933
Hello. The problem you're most likely having can be caused by a defective or clogged case sensor assembly located on the left, outside wall of the dishwasher. The part number for the case sensor is DD94-01006A. It is mounted to the bottom of the brake assembly, part number DD94-01005A. The case sensor sends a signal to the main board telling it how much water is entering the washer--if this part is defective, it must be replaced as it is not serviceable. The dishwasher must be pulled out at least halfway to access the parts. Be careful when removing the brake assembly and separating the 2 parts--take photos and/or make a diagram of how the parts fit and be careful when removing the wiring connectors. REMOVE POWER BEFORE WORKING!! If you are unsure or hesitant about any of this, call for service.
Aug 28, 2015 | Samsung DW7933LRASR New 24 Dishwasher
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
Apr 17, 2015 | Washing Machines
Why My Samsung DW7933 Series Dishwasher starts a wash cycle then makes series of beeps and stops with Quick ligt flashing?
That indicates a drain error. You may have something hard caught into the impeller of the drain pump, or your might have a bad ECS sensor causing that (false) error code.
Feb 13, 2015 | Samsung Dishwashers
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Samsung DW7933LRAWW 24" Tall Tub Built-In Dishwasher With Tact-Button Logo
223 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
