Question about Air Purifiers
Lasko ceramic heater how to clean - Air Purifiers
    Problem Solver:
Blow compressed air through the front of the heater and then vacuum the back of the heater. That shouild do the trick but take note that there appears to also be a switch that detects if the unit is tipped over. With the heater in the upright position you may also need to lightly bang the unit on its bottom before the it will start to run again.
Posted on Nov 05, 2013
Lasko blower fantype DTB E20739 PM7331
to clean your fan from dust
Jul 02, 2013 | Air Purifiers
Ceramic heater only blow cool air
Unplug the unit and look on the bottom or the back, there may be a circuit breaker reset switch.
If not, it's probably a fuse that's blown inside the unit and isn't made to be replaced.
Sep 24, 2012 | Lasko 6405 Designer Series Osc. Ceramic...
I have SYNAIRG4 ....digital readout said 'perform cleaning'....I did....to out filters washed and replied, put in new ceramic plate...restarted it.....digital read out...'perform cleaning'.....what now? I...
The metal contactors and the wire spade connectors get pretty corroded and can cause continuity problems . I have had to replace those spade connectors and clean the metal contactors with emry sand cloth. Another trick is to soak the plate in ammonia to reduce the corrosion present on the grids
Sep 28, 2010 | Ecoquest Fresh Air Air Purifier
My Lasko 42" Wind Curve fan when I plug it don't power up. Pluged at diferents outlets, same results Thank you
Check out the cord, (frayed or broken) usually right where it enters the unit, and the switch.... if these check out then the motor has gone bad...
heatman101
Aug 18, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
How do you clean the ionizer in a lasko wind curve
You have to take the fan apart. They didn't design it with the convenience of the customer who likes to keep things clean in mind, so you have to get out a bunch of screwdrivers and stuff and roll around on the ground and fight with it until you get it apart. I posted a lengthy post on how to get this model apart, as I just did mine yesterday. Just look for my name on the Lasko models like this one. But be careful and don't try it if you don't think you can pull it off without getting hurt.
Jun 11, 2010 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
How to clean my Lasko 42 Wind Curve Platinum?
Yep... ALL the screws in the back mus come out as well as the base. The only real problem I had was that 2 of the screws were randomly triangle drivers instead of phillips/straight combo. Ya know they do it just to tick you off...
Nov 02, 2009 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
How do i clean a lasko tower fan model 2551 as it is dusty inside
best is if you have an air compressor and blow it out, if not, a paintbrush and vacuum will do. remove grill/cover if you have to. make sure unit is un plugged.
Sep 06, 2009 | Air Purifiers
Air Purifiers Logo
53 people viewed this question
Top Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Air Purifier Expert? Answer questions, earn points and help others
