Question about Bose Lifestyle V35 Theater System
No Power to Acoustimas bass module - Bose Lifestyle V35 Theater System
    Master:
  • 359 Answers
The bass module usually has its own power cord. Have you plugged this in and it is not turning on?
Posted on Oct 18, 2013
Woofer not powering on
Check the power unit inside woofer, it was cause for same problem in my creative surround.
Mar 30, 2008 | Bose Acoustimass 15 System
Got error 10 and dont know what to do
from REalMacoi your problem seems to be related with the AdaptIQ failing to do an active equalisation. HAve you connected the AdaptIq sense headphones on the AUX (left and right coz it will still fail if only one cable is connected) Also make sure tha the sense headphone cable is in the correct color orientation and none is connected to the black jack just below the red one. Try this procedure and if the system still shows error 10 do the following in sequence...
1. Turn off the media center via the"ALL OFF" button in the tray (no DVD disc inside the tray)
2. Turn off the bass module by the power switch underneath the bass module (certain versions may not apply)
3. Unplug the power adaptor of the media center and remove the power adaptor connection from the wall socket.
4. Unplug the bass module (if this has not yet been done
5. Disconnect all speaker wires (satellite speakers I mean)
6. Disconnet the data cable linking the bass module and the media center
7. Allow 10seconds to pass
After 10seconds then connect the following again in this sequence
1. Connect the media center and the bass module data cable first
2. Connect the satellite speaker cables.
3. Connect the media center adaptor (DO NOT TURN ON YET!)
4. Lastly connect the bass module power cable (DO NOT TURN ON YET!)
Once verything is connected, press power "ON" button o nthe RF remote and the media center should turn on. Only the you should switch the bass module power "ON" so that a fresh handshake is achieved.
This ERROR 10 occurs when either the ADAPTIQ process is interrrupted, the data calbe link between the bass module and the media center is loose or when the power connection is interrupted.
If all still fails, then there is a problem with the DSP board of the bass module and would require servicing.
I do hope I was able to help you
Sep 21, 2010 | Bose Lifestyle 28 System
I have hooked this up to a working reciever that
Fill in the blanks about the working receiver.
You mention another subwoofer, which suggests your receiver manages the bass and possibly sends most or all of it to the sub.
If it's NOT sending the bass to the speaker terminals you use to drive the AM5 that would explain it's virtually silent bass module.
If those speaker terminals on your receiver can be set to LARGE, do it. Otherwise they assume the speakers are incapable of handling bass.
Apr 02, 2010 | Bose Acoustimass 5 III System
Very little bass coming out of bass module
No I haven't, but for me is the same.. Very poor bass, I'm already in week test and I'm thinking to return it.
Did you solved?
Jan 09, 2010 | Yamaha YAS-70 Front Surround System Black...
Bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Apr 05, 2009 | Bose Lifestyle 18 System
Code 10
Hi, your problem seems to be related with the AdaptIQ failing to do an active equalisation. HAve you connected the AdaptIq sense headphones on the AUX (left and right coz it will still fail if only one cable is connected) Also make sure tha the sense headphone cable is in the correct color orientation and none is connected to the black jack just below the red one. Try this procedure and if the system still shows error 10 do the following in sequence...
Apr 03, 2009 | Bose Lifestyle 18 System
Bose Acoustimas with error 10
Error 10 is either a disconnect from the audio input cable (check the pins on both ends) or the Acoustimass module has no power. Check the outlet etc. If resetting it (unplug both components for 30+ seconds) doesn't fix the problem. Call Bose for a repair.
Aug 31, 2008 | Bose Lifestyle 28 System
Interface module and/or bass module power problem
Eric,
Take their offer Bose is not that forgiving.
Send it back let them deal with it.
If you try to DIY it you'll void warrenty and will be totally SOL
Good luck
May 12, 2008 | Bose Cinemate Digital Home Theater System...
Bose lifestyle no sound
Hi, best practice when troubleshooting a no-sound Bose Lifesytle system is to first begin with the internal sources (i.e. the AM/FM). Bose Lifestyle system when connected properly (media center and bass box via the data cable) should show a steady green light underneath the bass module. Begin by simply playing AM/FM tuner and try to increase the volume till 45 (normally the sound becomes audible at this level). If the system still has no sound, then try to check if the bass module is steady green. When you see a blinking green LED (slow green) then do kindly check the DIP siwtch (red latch switch with white mini switches) just beside the Light and data connection. All of the switches should be in "ON" position (basically toggled upwards with the arrow marking indication). Before changing DIP switch settings do ensure that the bass module is not connected to the electrical power. after ensuring that all DIP switch are in the "ON" position, connect the data cable firs and then power up the bass module. Then you should see the bass module blink green twice and once you turn on the nedia center, the green blinking should turn steady green. That should sort out your problem.
Also do note tha this procedure applies only to Series II Lifesytle System and does not include the Series IV (with the smaller bass module).
If all still fails, there is an internal problem with the bass module which would require servicing.
Hope this helps!
Jan 27, 2008 | Bose Lifestyle 18 System
Bose Lifestyle V35 Theater System Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
