Question about Sharp Office Equipment & Supplies
ERROR 3333 Test Connection to server LDAP fail.
Cannot access to Exchange email address before scann and sent a doc by email using NTLM protocol
4 Suggested Answers
fer_nan_14
  • 76 Answers
SOURCE: Can't fine servers during LDAP search
hi
try to change the setting of lancard speed to half duplex of photo copy machine
Posted on Dec 11, 2008
  • 2072 Answers
SOURCE: LDAP lookup fails on Xerox WCP4150
I would check your software version. Several of the older versions had a lot of LDAP problems.
You can print out a system report and find your Firmware level, then go to Xerox.com, go to Drivers and Downloads and see what the new version. Current firmware level is 10.100.46.000 . follow the instructions.
Posted on May 12, 2009
  • 51 Answers
SOURCE: Can get LDAP search working on BizHub 350 Multi function copier
the smtp serwer wos chench u nead to setup scan for email whit new seting of smtp
Posted on Aug 30, 2009
Emails not sending with an error message.
Looks like your email address is being blocked. Test with another account or even device.
Apr 19, 2013 | Microsoft Outlook Express
Email problems: error code 0x800CCC0F,
When you use Microsoft Outlook Express to send and receive mail to a Post Office Protocol 3 (POP3) or Internet Message Access Protocol (IMAP) server running Exchange 2000 Server or Exchange Server 2003, you may receive the following error message. Your server has unexpectedly terminated the connection. Possible causes for this include server problems, network problems, or a long period of inactivity.
Sep 29, 2011 | Microsoft Internet Explorer 7
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
LDAP issues with Konica C451
5 Network settings
5-52 bizhub C650/C550/C451 (FE3)
Setting up LDAP
Register LDAP servers and specify authentication settings. Settings can be specified for the following.
Setup LDAP screen 1/6
Setup LDAP screen 2/6
Setup LDAP screen 3/6
Setup LDAP screen 4/6
Parameter Description
LDAP Server Name Type in the name of the LDAP server to be registered.
Use the keyboard that appeared in the touch panel to type in the server name (32
characters or less).
Max. Search Results Specify the maximum number of destinations to be displayed after a search. To
change the setting, press the [C] (clear) key, and then use the keypad to type in
the desired setting. (Range: 5 to 1000)
Timeout Specify the maximum wait time for a search operation. To change the setting,
press the [C] (clear) key, and then use the keypad to type in the desired setting.
(Range: 5 to 300 seconds)
Initial Setting for Search Details Specify the initial search conditions for "Name", "E-Mail", "Fax Number", "Last
Name", "First Name", "City", "Company Name" and "Department" in an advanced
search.
Server Address Specify the address of the LDAP server. Use the keyboard that appears in the
touch panel to type in the address (255 characters or less).
Search Base Specify the search starting point in a hierarchical structure arranged on the LDAP
server. Searches are performed by also including the sub-directories lower than
the starting point that was specified.
Use the keyboard that appears in the touch panel to type in the address (up to 255
characters).
SSL Setting Select whether or not SSL (data encryption) is used when connecting to an LDAP
server.
When SSL is used, communication information is encrypted.
Port Number Specify the port number for the LDAP server. To change the setting, press the [C]
(clear) key, and then use the keypad to type in the desired port number. (Range: 1
to 65535)
Port Number (SSL) Specify the port number when SSL is used. To change the setting, press the [C]
to 65535)
Authentication Type Select the authentication method used for logging on to the LDAP server.
Anonymous: This authentication method does not require a user name and password.
If "Anonymous" is selected, dynamic authentication is disabled.
Simple: This simple authentication method requires a user name and password.
Be careful since the passwords can be leaked over the network.
Digest-MD5: This authentication method can be used on a typical LDAP server. If
authentication fails using Digest- MD5, the authentication is performed by automatically
switching to CRAM-MD5.
GSS-SPNEGO: This authentication method can be used with Active Directory in
Windows (Kerberos authentication).
NTLM v1 and NTLM v2: These standard user authentication methods can be used
with Windows NT.
They can be used for logging on when sharing files and printers.
bizhub C650/C550/C451 (FE3) 5-53
Aug 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Jul 31, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'a.tia62@yahoo.com'. Subject 'testing', Account: 'mail.eastern.com.ph', Server:...
Greetings,
this is a server rejected recipient error message for Outlook/ outlook express. mainly if this is a correct email address that you were trying to send the email on then you need to check for the configuration settings for Outlook express.
Goto Outlook express- higlight mail tab- select the user a/c- click properties on right- goto server tab check that server is
incoming: pop3.eastern.com.ph
outgoing: smtp.eastern.com.ph
click save
Regards,
TechSup1
May 01, 2009 | Computers & Internet
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
Error message #80070002 treo 750
Ok, email can be setup using a bunch of different protocols. The difference is how directly you phones data and the data on the server interact. POP and IMAP are methods for receiving email from the server, to send they use a protocol called SMTP. With POP3, email is all downloaded to your phone and saved there, with IMAP you only download the headers (...a header is like the back cover of a book). An Exchange server can do SMTP with either POP or IMAP, but when it says configure for Exchange - it means actually connecting to the mail server and integrating contacts, calendar items, email, like the Outlook client on your Windows machine. This is obviously much more server intensive and requires special permissions to do.
POP and IMAP will require the following information to work. Your login name, your password, your server, and whether the connection is secure. To find these out you can go to your coporate webmail. The user name is what you put in the user login spot, as is the password, the server will usually be either mail followed by a dot and the second half of your email address, or the web URL for the mail server...if the web access page address starts "https" then the connection is most likely secure.
This link may help further...
Jul 22, 2008 | Palm Treo 750 Smartphone
344 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
