Question about Titan Controls 12 Site Flo-N-Gro Irrigation System | 702790
My flo n grow wont drain - Titan Controls 12 Site Flo-N-Gro Irrigation System | 702790
  • 21 Answers
Check for blockages
Posted on Mar 31, 2014
My spa pool is coming up with FLO flashing where the temp is shown, its a sunbeam and now wont hold temp
when a spa shows flo in a alarm message (like yours) this is a indication that the flow sensor is telling you that it has not enough flow thru the filters this most times disables the heater so it wont become overheated , Most times its caused by dirty filters or a foreign object getting past them , but ive also seen very poor water chemistry cause a false showing of this message , this usually requires a sensor replacement and correction of water chem to correct this
Aug 30, 2015 | Pool & Spa
Removing the lid from a hayward power-flo matrix
Too Much Pressure????
Are you trying to remove lid when the pump is on? NO, NO, NO
If not, then good! If you have valves before and after the equipment, then close them. Then remove the small 1/4" drain plug to empty the pot. Then try removing the lock ring and open it up.
Jul 13, 2013 | Hayward 1hp Power Flo Matrix Above Ground...
Power a air flo controller wont power up
Call Power A up and tell them they have a crappy product and tell them they should have better quality products...
Oct 13, 2012 | powera Cpfa010022 Air Flo Controller For...
Dishwasher won't drain
did you just change the gd? if you did take the knock out out of it
Jun 05, 2010 | Whirlpool 24" Bisque BuiltIn Dishwasher...
Hot tub pump flo-master hp suddenly wont start. it' one year old and was working perfectly. air side started to make a squealing noise the night before. draining hot tub to check volute to make sure motor...
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Sticking solid to the bottom wont move.
If you have to much suction This can keep the cleaner stuck in one spot. Once the cleaner sticks to the floor the flapper won't move because of low water flo. If the cleaner only sticks when it hits the main drain then you still have suction through the drain and need to shut it down or plug it off. The suction from the drain and the cleaner suction will cancel each other out and cause the cleaner to stick to the drain. A main drain is a misnomer it is properly called a deep suction, as it's job is to collect heavy dirt. The cleaner is a roveing deep suction and replaces the main drain. So you no longer need it and can feel free to plug it if you have to. Good luck.
Dec 22, 2009 | Universal Kreepy Krauly In-Ground Pool...
Titan Controls 12 Site Flo-N-Gro Irrigation System | 702790 Logo
327 people viewed this question
Top Titan Controls Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Titan Controls Garden Expert? Answer questions, earn points and help others
