Question about Car Audio & Video
How to hook up autotek speakers in the rear for caprice classic 92???
Autotek693T speakers and I don't know how the wiring goes. Someone plz tell me how to hook these up plz.
  • 960 Answers
Easy fix. The factory has fitted a special socket to connect direct to factory speakers. Just cut this off and connect the wiring from your new speakers to the factory wiring. Use insulated connectors or solder and tape up the wiring. Make sure that the speaker wire with a "trace" or line of colour through it marries up with the same wire in the car. Cheers.
Posted on Oct 18, 2013
2 Suggested Answers
pjstanley
  • 185 Answers
SOURCE: 08 ford fusion need to know the colors of both rear doors speakers
well first to decode the wire corlusthe darkest one is all wayz negtive. and a 18, or a 16 gauge wire should would work fine run it to ur amp from the fuse box let me no if that works
Posted on Apr 06, 2008
I have a 1992 chevy caprice classic and I'm working on the rear speakers. What if right speaker is only working???
Check the Balance control first
Trace your wires to make sure you have them connected properly
Use a 1.5v flashlight battery to determine if your wires are connected all the way back to the speaker. Just touch the neg and positive on the ends of the battery, you will ghear a click in the speake if you have the right wires.
Oct 18, 2013 | Car Audio & Video
How to hook autotek693T speakers in cparice classic 1992???
yeah, you are going to have to cut off that factory speaker connection, but leave a few inches of wire on the end so you can re-attatch that connector later, should you sell the car, re-install the factory speakers and keep your after market speakers for another car. one of the wires has a stripe on them, (never mind the color) connect the stripe factory wires to the stripe speaker wires with 'wire-nuts', or twist the bared wire and tape them with electrical tape, the stripe wire to the positive speaker post. the other wire will of course go to the negative speaker post. once you have both speakers wired up, play some music with good bass, and move your speaker balance from one side to the other, if your speakers are connected properly you will hear more bass with both speakers than with the balance all the way left, or all the way right.
Oct 17, 2013 | Car Audio & Video
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
I changed out my alternator on my 1994 caprice and my ac stopped working what has happened to it. I t was working fine.
make sure the wiring is all hooked up and also i believe the compressor ground wire goes to alternator bracket, take a look for any wires left off,
Jun 10, 2010 | 1994 Chevrolet Caprice Classic
I need to know the audio wiring for a 1993 caprice classic
1993 Chevrolet Caprice Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
pls rate
Sep 09, 2009 | 1993 Chevrolet Caprice
Were do i hook up my other hoses for my heater core
from the radiator ? If that is the case, the other one goes to the thermostat housing outlet.
Feb 17, 2009 | 1995 Chevrolet Caprice Classic
Autotek Bass Thrust 44 Wiring
thin blue wire is the remote wire and goes to the deck remote line
large diam wire goes to battery
large diam "black" goes to ground
rca ... wires with the metal ends plug into the white and red holes
you have two sets of speaker wire comming off the amp also
hope this helps
Dec 11, 2008 | Car Audio & Video
Aplifier gettieng protection signal and excess heat
for that amplifier, it is recommended that you are driving a 4 ohm load. It can drive a 2 ohm load, but will produce more heat and shorten the life of the amplifier. Is the subwoofer a single or dual voice coil? You'll want to make sure that you're not running below a 2 ohm load or you'll always go into protection. Also, try disconnecting the speaker wire completely from the amp so nothing but power is connected. If the amplifier is still in protection mode when no speakers are hooked up, then the amp is bad and will need repair or replacement.
Sep 28, 2008 | Autotek Car Audio & Video
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
