Question about Beckett Corporation Beckett W3500 7114310 Large Pond Waterfall Pump
I have a Beckett W3500, and it seems to be blocked. I hear a buzz when the power is on, but it is not pumping water. Is there something I can check before having to go and buy another pump?
3 Suggested Answers
  • 10865 Answers
SOURCE: Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
Posted on May 02, 2009
  • 151 Answers
SOURCE: my beckett 300gph pump trips breaker and works
capacitor,windings failing,
Posted on Dec 24, 2009
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
Hmms but won't pump
Hi, by what you have said I believe that the pump is stuck and firstly dont leave it on it will be seriously damaged. I recommend that you remove the cover to access the impellor. If this is to difficult you should be able to insert say a screw driver to try to move the impellor. Obviously before doing anything disconnect the power to the pump. You will probably find some crud in the impellor housing stopping the pump from turning.
Hope that helps
Steve
Apr 10, 2014 | Beckett Corporation Beckett W3500 7114310...
I have an oil burner that is leaking. how can i determine if it is oil pump or something else?
Do you see oil or water? If oil then the pump seal is broken and you need oil Tec to change the pump.
Dec 31, 2013 | Beckett A2EA6520 Single Stage Clean Cut...
Beckett W3500 pump parts
go online and put the model number so you can find the pump first. then find broken part. if the pump cannot be found use any number on the broken part to locate what you need.
Jan 24, 2013 | Garden
Buzzing noise
hi, it sounds like the brushes on the motor 2 plastic blockes sit either side of the motor thses are made of carbon and wear down can cause the motor to stop working hope it helps
regards
shaun
Jan 05, 2012 | Washing Machines
We have a Beckett W5000 a rock got in the systems and broke the plastic puppelor. Where can we buy trhe part to fix it???
Email Beckett at: customerservice@beckettpumps.com
Call Beckett at:
972-871-8000 or Toll Free at 1-888-BECKETT (232-5388)
Fax Beckett at:
972-871-8888
Write to Beckett at:
Beckett Corporation
c/o Customer Service
3250 N Skyway Circle Dr
Irving, TX 75038
Warranty & Technical Assistance:
The NEW toll free number for warranty information, replacement parts, and technical assistance with water gardening and fountain products is 866-466-4319 or email Beckett atCustomerCare@beckettpumps.com
For information on CE, VDE, or DENAN (PSE mark) certified pumps:
Please email Beckett at: customerservice@beckettpumps.com
Or write to them at the address above.
Aug 28, 2011 | Beckett Water Gardening Beckett Statuary...
Our Indesit dishwasher D1620 is not draining at the end of the programme. I have checked the hose its not kinked and there is nothing blocking the drain point. Any ideas what we can do?
When you put the dishwasher on for a new cycle you should hear the drain pump operating for a short while before it allows any water to enter the machine.If all you can hear is a buzzing noise then it is probable that something is stuck in the drain pump or the pump is faulty.If this is the case then you will need to access the drain pump through the removal of the side panel.
Hope this helped.
Jun 13, 2010 | Dishwashers
This is an older beckett pond pump about 550 gph. The impellor will not turn unless you give it a spin . Could it be the capacitor ?
check bearings may need to be lubed then check motor amp draw if within specs then test cap if weak or not holding charge replace
Mar 25, 2010 | Beckett Water Gardening Beckett Statuary...
May 02, 2009 | Beckett Corporation Beckett Professional...
Beckett Corporation Beckett W3500 7114310 Large Pond Waterfall Pump Logo
43 people viewed this question
Top Beckett Corporation Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Beckett Corporation Garden Expert? Answer questions, earn points and help others
