Question about ASUS Computers & Internet
RT-AC66U slow download speeds
    Master:
  • 359 Answers
Run a test of your internet using www.speedtest.net. You should be seeing ping less than 100 ms, and your download and upload speeds will vary depending on your service. Do you have cable, isdn, dsl, or fiber? cable and fiber should give you speeds of at least 10Mb down 10 Mb up, ISDN and DSL should give you speeds around 500kbps down and 250kbps up.
Posted on Oct 17, 2013
Ip conflict
Enable DHCP in the router and check all the connected devices after you login to the router page. You will find the name of ur printer enlisted in the router login page where all the ip address will be reflecting. Make sure ur WAN ip series is different from the DHCP pool which typically starts with 192.168.x.x.
Please keep me posted
Jul 24, 2014 | ASUS RT-AC66U 802.11ac Wi-Fi router
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
NAS Disconnecting from Network
I hope the brothers who has a program Printer Definition "murtec mfx 2010" Windows 7 download link here Vlada graciously
Mar 10, 2014 | LaCie d2 Network v.2 - 3TB
As66u wifi connection loss
Many thing interfere with a signal, even the iPad's antenna, which is a known problem, see: http://osxdaily.com/2012/03/21/fix-new-ipad-3-wi-fi-reception-problems/.
Mar 19, 2013 | NA Asus RT-AC66U Wireless AC1750...
Rt n53 asus slow wifi
So, If you have internet connection speed problem with your wireless try with the following steps,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Nov 18, 2012 | ASUS Rtn53 - Rt-n53 Wireless Router - Ieee...
My yamaha rt 100 wont idle
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha rt 100 is not idling Motorcycle Forum
Yamaha RT100 Carb Rebuild Cleaning
1990 2000 YAMAHA RT100 Service Manual Repair Manuals AND Owners Manual...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-rt-owners-manuals
Sep 01, 2012 | Yamaha Motorcycles
SLOW ACCELERATION
Based on the symptoms you described you have a slipping transmission, is the fluid dark and burnt smelling?
May 19, 2010 | 2001 Dodge Stratus
Error code of "Er s" appears on the display and inside the light remains on at RINSE Low. HELP!
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
Service Test
Let me know how this works out for you.
Benjamin
Slow internet access wirelessly
You can open up devise mgr,(rt click on my computer,click properties,click devise mgr) now look down, you should see network
adapters, you should see on that says wireless, if you rt click on it
and pick update driver, then choose search internet, try this two times, if it finds a newer driver,you will need to restart your system
and hopefully it will run better, or you can see who makes the wireless hardware and go to there site and see if there is a newer driver then the one installed, before you do this,click on driver tab and look at the date of driver, just so you are not getting the same one.
Now if you have the newest driver and still have a slow speed, write down the make and model of the hardware, now go to speedtest.net and run a speed test. Now post back what the hardware is,, the speedtest results,and what OS you are using,xp,vista, and I or someone can explain how to tweak your speed. Hope your driver updates and it works out for you.
Mar 23, 2009 | Toshiba X205-S7483 Notebook
Computers & Internet Logo
224 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
