SOURCE: low oil pressure
usually that could mean a failing oil pump....or a clogged pickup in the oil pan, could also mean you have a leak somewhere. the car shutsoff because it protects itself from killn itself
SOURCE: High temp oil light coming on and off, oil pressure gauge reading
Add the quart of oil. Oil also acts as a coolant.
SOURCE: 97 F350 diesel check engine light stays on and is running rough?
Ok, lets take this from the top. I have a 97 f250 diesel. In mid may mine did the same thing. It's either one of two things. You have under valve cover harnesses (uvc). They slide in under your valve covers, you will see two wiring harnesses on the outside of the valve cover gaskets on either side of the block. Ok, it IS possible one of these slipped out of place and killed two of your injectors, causing the horrible running/ low idle/no power/ sounds like the truck is going to stall symptoms. The easiest way to check that is to unplug the wires while the truck is running and see if it kills the engine, if it doesen't unplug the other one on the same side of the valve cover. If both of these don't cause any change then you have a bigger problem, the IDM (Injector drive module).
FAIR WARNING: When you unplug the wires with the truck on it is extremely dangerous, it is 110 volt feed. It can kill you.
OK, the IDM is a silver box, 8"x10" approx dimensions, located on the driver side under the hood, over top the front tire. If you take the wires you unplugged and take a multi meter to them and they are dead, you have a bad IDM. This was the case with my truck. Ford designed the IDM to have a hole in the side to allow condensation to escape from it, unfortunately, this allows water inside and will short out resistors and practically kill half of your engine. Buy a new IDM on ebay for about $380. It takes 5 minuts to put it in.
I hope this helps you out man.
SOURCE: 2007 Ford expedition won't start
ur oil pump may be failin-there r sensors everywhere on new cars-keepin u from starting as safety measure-computer systems r complex n things dont always show on 1 scan-they kinda hav the mindset of a pc
Testimonial: "Thank you. I have spoken with 2 other mechanics who said the same thing regarding the oil pump. It's being looked at. So I'll post more once I know"
