Question about Husqvarna Garden
Loses power while driving - Husqvarna Garden
  • 76 Answers
I would suggest checking the gas cap on it first. If the vent hole in them gets plugged up it can cause it, so loosen the fuel cap and see if it helps. Other things to check is if it need a tune-up on it, a plugged up muffler can cause it, check the fuel filter if it has one and maybe clean the carb out. If the problem is still there after that have the compression on the engine checked as low compression can cause it also.
Posted on Oct 21, 2013
Lose of powe up hill no warning lights and idle is good
Fuel filter air cleaner filter plugged or need a tune up or air sensor in intake line put on computer will tell you right away if you want
Jan 12, 2016 | 2004 Nissan Altima
If you have a manifold gasket leak on a '07 trailblazer ss would it make the vehicle lose power when driving down the highway
A manifold gasket leak will cause a power loss everywhere you drive, although a hot engine may lose more power than a cold one. You can check you spark plug color. A manifold leak makes a lean mixture so the plug should show the typical white-ish deposits.
Apr 23, 2014 | 2007 Chevrolet TrailBlazer SS
My mitsubishi galant loses power while driving and the neutral light indicator starts to blink then suddenly picks up speed with a jolt. I flushed the transmission fluid to clean the bottom pan and...
You will have to repost and reword this problem... you say it wont move, but that it loses power while driving. how is it losing power while driving if it wont move?
Feb 11, 2014 | Mitsubishi Cars & Trucks
Esp light on 2001 aclass
Hi there lose of power steering and the eps light coming on could be the power steering pump is broken or near stuffed so will require a new pump. The other reason is that your power steering oil level is to low and needs toping up. Also check that the drive belts driving the power steering pump are tight and not slipping.
Hope this helps.
Mar 31, 2013 | Cars & Trucks
1999 Jeep Grand Cherokee Laredo 8Cyl4.7L When when driving over 50 miles per hour will lose all power whats wrong?
When you say it loses power, do you mean electrical power or engine power ?
You would need to look at the fuse boxes for a loss of electrical power, and use a scanner or code reader to check the computer for trouble codes for a loss of engine power.
Sep 18, 2012 | 1999 Jeep Grand Cherokee
Car loses power after driving for a while
fuel pump may be going out stand by the end of the car and try to ear the pump making sounds if it dosen't make any sounds then it bad hope this info helps
Mar 06, 2010 | 2000 Ford Focus
Loses power while in drive.
To what degree do you lose power and in what way? Do you loose over-drive or does it loose power and speed (on the streets, highway, or at any speed). From your discription it does sound like either a fuel flow/pressure issue or a clogged cat.
Mar 15, 2009 | 1997 GMC Safari
Loses power when driving
May just need tighten up a little check the belt see if its dry rotten.
Aug 16, 2008 | 1998 Honda Civic
Garden Logo
26 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
