Question about Pride Jazzy 1113 Power Chair
Pride jazzy 1113, controller light scroll back and forth, wont move, i bought one new battery, it has full charge other battery is a little over 10 volts. is there way to test charger with volt meter?
  • Pride Master
  • 9,639 Answers
The voltmeter should read 29 volts when on. You should never replace one battery and leave an old battery in the chair. Replace them both at the same time.
Posted on Feb 24, 2015
3 Suggested Answers
  • 177 Answers
SOURCE: Jazzy 1113 ATS Indoor Power Wheelchair: the battery is fully charged but it wont move does...
Hi. Your machine probably has a fault, but I very much doubt that it needs reprogramming.
Are the free-wheel levers in the correct place? Is the machine displaying any fault codes, e.g. flashing LED's and what is the pattern or number of flashes between pauses?
Good luck. Neil.
Posted on Jun 01, 2010
  • 692 Answers
SOURCE: JAZZY 1113 AFTER CHARGING 10
Mary yep Even though the batteries are charging they are not holding the charge to provide enough power for the chair. Usually you have one battery that is weak and causing the problem but both batteries must be replaced. If Medicare paid for your chair then they will pay for 80% of the new batteries. You can contact the provider that sold you your chair and ask if they can replace your batteries. If not, you can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have tech come out and repair the chair for you and they will bill Medicare for the cost of repair. Hope this helps
Posted on Feb 28, 2011
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 power chair shows charged but control light is blicking. Chair will not move.
It appears that the controls are in Lock Mode. Unlocking Instructions depend on your type of controller. Go to PrideMobility.com to download the proper manuals for chair and controller.
Feb 11, 2013 | Pride Jazzy 1113 Power Chair
Won't move lights are flashing on the controller batteries are fully charged any help
Doug I need to know how the lights are flashing ie 4 times pause 4 times pause etc or are all the lights flashing slowly or are the lights scrolling from left to right or right to left Thanks
Apr 28, 2011 | Pride Jazzy 1113 ATS Indoor Power...
My wheelchair shows full charge, 2 hours later, it is blinking and out of charge. This happens while I am at work and just setting at my desk. We had batteries tested and they are fine.
Pride has a problem with a battery cable that will draw down the batteries like you say just sitting there and I'm not sure if it is with the Jazzy 1113. I would contact Pride @ 1-800-800-8586 ask for Jazzy Tech support and explain your problem. They should be able to tell you more specifically what the problem could be. I still think the batteries can be a cause of your problem but the Jazzy folks can help Hope this helps
Mar 19, 2011 | Pride Jazzy 1113 Power Chair
Jazzy 1113 Unit has a full charge, but won't move. Battery indicator LED's go from empty to charge a couple times then flash the red and yellow. Think it might be the throttle pot. If so is it possible to...
Go ahead and try this web site.It will give you the flash codes and narrow down your search to finding the problem.http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Jan 22, 2011 | Pride Mobility Products Jazzy 1113 ATS
The jazzy 1113 will not start, when you press the power button the speed light comes on gets full and then turns back off
How old are the batteries? If you've had them for a few years it might be time to change them. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1113 http://www.replacementupsbattery.com/UB12350-NB.html
Nov 08, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Good luck. Neil.
May 16, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 will not operate!
The click you hear when you activiate the joystick is the electric solenoid on the automatic brakes going on, and then off when you push then release the joystick. This is normal. If it isn't moving, check to see if the free-wheel levers are in gear or in neutral. If you can push the chair, you are in neutral and activating the joystick will just release the brake and run the motors. Turn the two levers to the drive position and then it should take you where you want to go.
You can go to Pride Mobility's website to download an owners manual for your chair here
http://www.pridemobility.com/jazzy/1113ats.asp
Good luck.
Jul 05, 2009 | Pride Mobility Products Jazzy 1170 XL Plus
My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Pride Jazzy 1113 Power Chair Logo
173 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
